Old 6th Mar 2020, 6:52 pm   #1
Cre8anet
Cre8anet's Avatar
Default Old telecom Plug name? (4mm x 3-pins)
Anyone recall those old telecoms Test Leads? The ones that had 3-off 4mm pins, two spaced at 19mm plus a third earth pin ...
I want to Google a couple for my "new" 1980s AF tester - we repair local PA gear for community halls & churches and meter has 3-way skts, so where to look or what them pesky 3-ways were called would be very kind!
Thank you,
Dave
~~~~~~May your Waves be Long~~~~~~
Cre8anet is offline
Old 6th Mar 2020, 8:13 pm   #2
Radio Wrangler
Radio Wrangler's Avatar
Default Re: Old telecom Plug name? (4mm x 3-pins)
We knew them as 'Siemens 3-pole' and they were on a number of HP telecomms testers such as 3770A 3724A with the appropriate options.
Radio Wrangler is offline
Old 6th Mar 2020, 8:33 pm   #3
Cre8anet
Cre8anet's Avatar
Thanks for info - had a feeling they were Siemens but not much shows up... Any more insights anyone?
Cre8anet is offline
Old 7th Mar 2020, 2:45 pm   #4
Herald1360
Herald1360's Avatar
Time for 3 banana plugs, a bit of paxolin and some araldite?
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 7th Mar 2020, 7:30 pm   #5
dagskarlsen
dagskarlsen's Avatar
The only phone related 3 pin plug I remember is this configuration:
https://phone-jack.org/styles/images...pj-italian.jpg
dagskarlsen is offline
Old 7th Mar 2020, 11:54 pm   #6
Radio1950
I think this might be the one in question.
We also just called them "Siemens Three Pin".
Widely used in FDM and balanced audio systems.
Name:	Siemens Bal Plug DSC07886.jpg
ID:	200497   Click image for larger version
Name:	Siemens Bal Plug DSC07887.jpg
ID:	200498   Click image for larger version
Name:	Siemens Bal Socket DSC06505.jpg
Radio1950 is offline
Old 10th Mar 2020, 7:11 pm   #7
Cre8anet
Cre8anet's Avatar
Thank you so much folks... you covered the field for me there - especially the last one which is same as my kit I think.
Cheers,
Dave
Cre8anet is offline
Old 10th Mar 2020, 7:46 pm   #8
dagskarlsen
One for sale at facebook?
Jiří Vávra‎WWII German Field Comm. and Funkers:
I hope this may help you. I do not know the seller, and I have never seen such plug
dsk
Old 12th Mar 2020, 5:39 pm   #9
russell_w_b
russell_w_b's Avatar
This looks remarkably like the handset pin-out connections on my 1956 Soviet TAI-43 field telephones which were, I believe, modelled on the WWII German 'Feldsprecher' telephones. 1/2" between the closest two pins, exactly the same as a standard PO-231 audio broadcast test-tablet plug, and 1 1/4" between the outer pins.
More than mere coincidence, I think.
Name:	Handset Soviet Fieldphone pin-out.jpg
Regds,
Russell W. B.
G4YLI.
russell_w_b is offline
Old 12th Mar 2020, 9:09 pm   #10
Radio Wrangler
I have a lot of them here in the radio shack. I use them for 13.8v DC power distribution. A couple of portable batteries have them attached as well. Chosen long before the Anderson PowerPole connectors hit the UK amateur radio scene.
