Old 22nd Sep 2018, 12:12 am   #1
Top Cap
Top Cap's Avatar
Default Odd Telecom fuses?
I found these fuses in a test meter that was owned by my late brother, he was a Telecoms Officer on the London Underground.
They are strange to me but probably well know to members here, the closest I can find them is inside a picture of a GEC box.
Two are marked 1/1.5 KBA Rated 1.5 Amp.
The other three are marked Dummy No.1 SFC
No use to me, I expect they are not rare so will dump unless anyone wants them?
Whether the Top Cap is Grid or Anode - touching it will give you a buzz either way!
Top Cap is offline
Old 22nd Sep 2018, 12:42 am   #2
Refugee
Refugee's Avatar
Default Re: Odd Telecom fuses?
What size are they?
Refugee is offline
Old 22nd Sep 2018, 11:22 am   #3
Top Cap
Top Cap's Avatar
53.63mm (2.11") long, body width 6.56mm (0.26"), cap width 7.6mm (0.3").
Top Cap is offline
Old 22nd Sep 2018, 11:30 am   #4
Refugee
Refugee's Avatar
They are quite long. Perhaps they are high voltage typed for equipment to measure live rail voltages.
Refugee is offline
Old 22nd Sep 2018, 1:31 pm   #5
Top Cap
Top Cap's Avatar
Yep, perhaps. Nearest I ever found are here in the pic of a GEC box.
The end caps are slightly pointed as if to fit into a sprung contact.
Top Cap is offline
Old 22nd Sep 2018, 2:06 pm   #6
space charge
space charge's Avatar
the dummies speak for themselves the others are standard fuses as used in suscriber protection unit . this would include carbons and an earth
pierce ei7ka
space charge is offline
Old 22nd Sep 2018, 6:36 pm   #7
TonyDuell
I was given a 'Protector, Heat Coil and Fuse' as in the above photo last year. Mine still had the heat coils, but the carbon spark gaps had been removed and the fuses replaced with dummies. The dummies in mine was just flat metal strips with shaped ends to fit into the spring contacts. I've attached a photo of the insides of it.
If nobody else has a need for them I could add the fuses to my collection to go in that unit (which I will never use on a 'real' telephone line of course).
TonyDuell is offline
Old 22nd Sep 2018, 6:42 pm   #8
Top Cap
Top Cap's Avatar
You are welcome to them Tony, please PM your address.
Also have a Robin 314413, Tester SA9083 Mk.18 if you want it.
Can't test it but the LED lights and passes basic tests, Yellow carry case shows signs of much usage though.
FOC of course.
Top Cap is offline
Old 22nd Sep 2018, 7:01 pm   #9
TonyDuell
Yes, the tester could be interesting too.
PM sent containing my address
