Old 10th Sep 2018, 11:58 am   #1
m_rawdin
Default Slow No10 dial
The No10 dial on my candlestick phone is a bit slow on the return so I was going to disassemble it and see if anything needs cleaning inside as the front of it is pretty dirty. I am slightly worried about the main spring unwinding, how is this held in place and which screws/parts should I avoid removing to make sure it stays in place? Is there a way of cleaning the main spindle/spring and lubricating it without touching the main spring and unwinding it?
m_rawdin is offline
Old 10th Sep 2018, 3:55 pm   #2
ThePillenwerfer
ThePillenwerfer's Avatar
Default Re: Slow No10 dial
Here are the GPO servicing instructions.
ThePillenwerfer is offline
Old 10th Sep 2018, 4:04 pm   #3
dagskarlsen
dagskarlsen's Avatar
Usually you do not have to dismantle it. The instruction sent in the reply over is good, more info here: http://www.britishtelephones.com/dial1.htm#d10
I would have tried to blow out the dirt, clean with a little brush and oil carefully. Do not use oil with silicone, it may cause problems later for the contact sets.
A thin watch, weapon, bike, sewing machine oil are usually OK, but you cant hardly get to little.
dsk
dagskarlsen is offline
Old 10th Sep 2018, 10:16 pm   #4
m_rawdin
Got it sorted, I took out the governor and governor gear, blew as much dirt out as I could and put a tiny amount of oil on any moving parts, it's going great guns now.
m_rawdin is offline
