Old 30th Nov 2020, 10:42 pm   #41
1955APREN
1955APREN's Avatar
Default Re: Faulty CRT Computer Monitor
Sorry for the delay I have in my shed a A34JXV70x53 with scan coils you are welcome to have FOC it but it will be collect only from north Shropshire . I don't think the Greek god
will look after it on a 200 mile + run
Regards
Derrick
1955APREN is offline
Old 15th Dec 2020, 1:01 am   #42
tjohnson
Regards
Derrick
Thanks thats very generous I might take you up on this if my current plan doesn't work and once all this covid stuff lifts.
I have taken the tube and yoke out the philips however the connector isn't a straight swap. The original yoke follows what appears to be a fairly standard configuration and colour combination
red & blue horizontal winding - green & yellow vertical winding
while the philips follows
red & black horizontal winding - green & grey vertical winding
I'm now concerned about getting them the wrong way round and impact this may have.
I believe on the original tube the blue and green are negative but on the philips it seems like the grey and black are negative.
They sure did make this ackward!
ID:	222533   Click image for larger version
ID:	222534   Click image for larger version
Name:	Original Right.jpg
ID:	222535   Click image for larger version
ID:	222536   Click image for larger version
Name:	Replacement Right.jpg
tjohnson is offline
Old 15th Dec 2020, 8:27 pm   #43
tjohnson
I went ahead and tried it today, some success but the picture is mirrored, it is showing backwards!!!
It's also quite a bit darker than the old picture even with the brightness turned all the way up.
Name:	Reflected image.jpg
tjohnson is offline
Old 15th Dec 2020, 8:31 pm   #44
Red to black
Red to black's Avatar
Swap the Horizontal scan coil connections over (with each other, ie. just that pair) and this will correct the image.
Red to black is offline
Old 16th Dec 2020, 1:28 am   #45
tjohnson
Cheers that did the trick. I also adjusted the sub-bright inside the monitor and got an acceptable brightness, the service manual refers to putting the monitor into "free-run condition" and then connecting a scope of the collector of Q802 and then obtaining 123-124v but I had no idea on what it meant by free-run condition, I thought it perhaps means connecting nothing , but using my scope I wasn't getting what the manual showed so I did it by eye. ICP-N20 was blown but the HOT wasn't, I didn't notice that there is an internal diode that made me think they were shorted together.
I need to tweak the horizontal and vertical positions slightly but it looks good, the picture is probably crisper than the old tube, unfortunately there are some surface scratches on the tube but since it was free I can't complain too much and I have a working monitor again!
tjohnson is offline
Old 20th Dec 2020, 1:54 am   #46
Kyle__B
Good work. I'm not surprised that the replacement tube is sharper, knowing amstrad the original was probably factory seconds.
Kyle__B is offline
