Old 23rd Jan 2019, 4:33 pm   #81
FERNSEH
FERNSEH's Avatar
Default Re: Baird T5 restoration project.
A new loudspeaker panel has been made. After several attempts at making the new panel a perfect fit I can sign off this stage of the cabinet restoration.
Now a decision on what to do with that front panel. Should I restore it or make a replacement? There's still a possibility that some nasties exist in the eighty year old plywood. You have to be ruthless when it comes to dealing with woodworm infestation. Any doubt cut it out!
DFWB.
ID:	176984   Click image for larger version
FERNSEH is online now   Reply With Quote
Old 23rd Jan 2019, 9:25 pm   #82
line sync
I wouldn't take the risk david, there might be dozens of sleeping woodworms in there waiting to come out in spring time so the sooner you get all that infested wood out of your shop the better.
This is a very interesting restoration you`ve taken on and I look forward to reading all the new posts.
Robin
line sync is offline   Reply With Quote
Old 23rd Jan 2019, 9:26 pm   #83
Ed_Dinning
More fodder for your next conflagration David!
Ed
Old 23rd Jan 2019, 10:13 pm   #84
FERNSEH
FERNSEH's Avatar
Hi Robin, Hi Ed,
I've decided that the front panel must be replaced. There could well be some horrors in the plywood waiting to destroy the cabinet again. And burn those old rotten parts as soon as possible!
Correction to my last post. The loudspeaker should be sited on the left side of the front panel.
DFWB.
Old 23rd Jan 2019, 11:04 pm   #85
Tractionist
Smile Re: Baird T5 restoration project.
Anobium Punctatum just luuuuurves plywood - in fact, it was 'introduced' into this country via Indian [plywood] tea chests! The early [cabinet] shots posted by David seem to show lots of fresh frass on the bottom of the unit - indicating live activity. So - I'd go along with everyone's counsel regarding incineration of the various remnants.
Generally, woodworm is relatively easily eradicated using 'toxic box' techniques i.e. treating all surfaces with something like Five Star Cuprinol [prior to introducing the item into your home!]. The hibernating beetles need to eat their way out of the host wood - and fly once per year in order to mate!
Treatment does not however rectify the unsightly 'flight holes' produced by these insects - albeit that a moderate attack can sometimes be carefully disguised. Fortunately, woodworm is rarely 'structural' in its effect [unlike say Deathwatch] - but it does weaken wood and expose it to other potential maladies e.g. rot/fungal attack.
And in this instance ....... David seems to have happened upon a 'rare example' !!!
Red to red, black to black. Throw the switch and stand well back!
Tractionist is offline   Reply With Quote
Old 24th Jan 2019, 8:51 pm   #86
FERNSEH
FERNSEH's Avatar
Tractionist wrote: "Treatment does not however rectify the unsightly 'flight holes' produced by these insects - albeit that a moderate attack can sometimes be carefully disguised. Fortunately, woodworm is rarely 'structural' in its effect [unlike say Deathwatch] - but it does weaken wood and expose it to other potential maladies e.g. rot/fungal attack."
Hi Tractionist Good advice. Next week I will make a new front panel. It doesn't make sense fiddling about with the damaged front panel because even it can be saved by using chemicals it will need re-veneering. So why not apply the new veneers to a new solid panel instead.
DFWB.
Old 24th Jan 2019, 10:29 pm   #87
Tractionist
I was hoping that you'd say that David - but I didn't want to double-think the maestro! That front panel is riddled - in fact it looks as tho' it's taken a few hits with 'grape shot'!
Stay with it - it's coming together ........
Old 24th Jan 2019, 10:44 pm   #88
FERNSEH
FERNSEH's Avatar
In fact the panel is so rotten it is possible to push a screwdriver blade through it.
However, the hardwood framework is in excellent condition so at least some parts of the original cabinet can be reused.
DFWB.
Old 29th Jan 2019, 12:16 pm   #89
FERNSEH
FERNSEH's Avatar
The construction of a new front panel has started. 12mm plywood will be used and the outer surface will be book matched veneered to resemble the original panel.
DFWB.
Old 29th Jan 2019, 7:11 pm   #90
FERNSEH
FERNSEH's Avatar
The rotten front panel was removed today. Superficially, woodworm holes apart, it looked like a solid panel but was in fact just like the other plywood panels - it resembled a Weetabix biscuit. Crumbled into dust.
DFWB.
Old 29th Jan 2019, 8:26 pm   #91
Tractionist
Have you scanned the logo/script?
Old 29th Jan 2019, 8:42 pm   #92
FERNSEH
FERNSEH's Avatar
Hi Tractionist
We've taken photographic pictures of the TELEVISOR logo. That's one feature of the set that must be preserved. It might be possible to save the control panel. It seems to be solid, but I said that about the front panel. The T23 has the Baird name on the control panel.
DFWB.
Old 29th Jan 2019, 8:48 pm   #93
Tractionist
Hi David - if you can lift that part of the veneer [with a Kraft knife?] without damaging it .... it may be a good idea to both scan it, and see if you can incorporate it into the new veneered panel [marquetry style] ..... after having treated the rear of it with Cuprinol etc.
This always assuming that it too isn't perforated with worm flight holes ......
Old 29th Jan 2019, 9:42 pm   #94
FERNSEH
FERNSEH's Avatar
Tractionist wrote: "Hi David - if you can lift that part of the veneer [with a Kraft knife?] without damaging it .... it may be a good idea to both scan it, and see if you can incorporate it into the new veneered panel [marquetry style] ..... after having treated the rear of it with Cuprinol etc."
I was thinking about something on those lines. The critical part of the restoration will be the removal of the control panel. This will have to be done in order the new front panel can be fitted. Let's hope it doesn't disintegrate when comes to releasing the joints between the control panel and the upright corner pieces.
DFWB.
Old 2nd Feb 2019, 12:14 pm   #95
FERNSEH
FERNSEH's Avatar
After quite a few adjustments the new front panel was test fitted yesterday. The next stage of the front panel reconstruction will be to cut out the aperture for the timebase controls.
DFWB.
Old 3rd Feb 2019, 4:18 pm   #96
FERNSEH
FERNSEH's Avatar
This week I'll have to make a decision what to do with those cabinet sides. They are solid enough but as the pictures show are full of woodworm holes. No doubt with the use of wood filler the holes can be made to disappear but there's always the possibility there could still be nasties in the plywood.
Worth taking a chance or make new panels? Bear in mind the set does not belong to me and I don't wish to disappoint it's owner when those tell tale holes appear again on the cabinet.
The side panels are easy enough to replicate. Use 9mm grade AB plywood.
DFWB.
ID:	177659   Click image for larger version
Old 3rd Feb 2019, 4:31 pm   #97
MonochromeMarc
MonochromeMarc's Avatar
Hi David,
I reckon you've answered your own question there
Better safe for the customer !
Marc.
MonochromeMarc is offline   Reply With Quote
Old 3rd Feb 2019, 5:13 pm   #98
FERNSEH
FERNSEH's Avatar
Hi Marc,
There's nothing special about the side panels, no book matching of the veneers so as long as the best wood grain pattern on the new plywood is chosen there will be no problems with the final finish of the replacement panels.
But before a final decision about the fate of the cabinet sides is taken, let's find out what the views of other forum contributors are about the matter.
DFWB.
Old 3rd Feb 2019, 5:17 pm   #99
ThePillenwerfer
ThePillenwerfer's Avatar
No point spoiling the telly for ha'p'orth of ply.
ThePillenwerfer is offline   Reply With Quote
Old 3rd Feb 2019, 5:24 pm   #100
FERNSEH
FERNSEH's Avatar
Hi Pillenwerfer,
I reckon those panels are for the chop! That'll keep me busy this week. No LCD TVs to be fixed when we're dealing with television history.
DFWB.
