26th Mar 2024, 6:52 pm | #1 |
Bush dac 10 resistor query
Just bought a dac 10 that's not working, no sound or illumination,the RF filter was totally blown and I've replaced that.
However r21 dial lamp shunt resistor is ,on my set a75ohm resistor,trader sheet says it should be a 250 ohm ,is this correct The 75 ohm looks totally original
If it ain't bust don't fix it |
26th Mar 2024, 9:02 pm | #2 |
Re: Bush dac 10 resistor query
This comes up regularly where Bush radios (DAC90A included) are concerned. The value of the resistor was changed at some time during the products' life cycle.
If the resistor measures OK leave it alone.
26th Mar 2024, 9:04 pm | #3 |
26th Mar 2024, 9:05 pm | #4 |
Thanks,it reads about 79 ohm so it well within tolerance,I thought it may have been changed at sometime in the past
