10th Jul 2023, 2:29 pm | #1 |
Old VHS machine springs back to life
I have a collection of several dozen old VHS tapes I recorded off-air in the 1980s and haven't viewed since then. These were recorded on a Fisher recorder - FVH-530? -(long gone) that I purchased in 1982 for around £600.
The Fisher carried on un-serviced for about 20 years. Some time later I was given an old JVC HR-D180EK machine in working order. What year would this have been made? Well, I haven't touched this JVC machine for at least the past 10 years, but today I thought it would be fun to try it out! So after taking off its cover to check there weren't any obvious nasties after long storage, I popped in my very first 1982-recorded tape. I attach the results, taken from the standard UHF output. The recorder worked more or less perfectly. On this tape, there were some Colour Bars and Test Card and music, presumably original from 1982. I now look forward to exploring the rest of my old tapes from the '80s... I have clearly been lucky! I have no experience with VCRs. Some guidance as to recommended servicing would be welcome. Steve
https://www.radiocraft.co.uk |
10th Jul 2023, 2:50 pm | #2 |
Re: Old VHS machine springs back to life
Yes - you have been lucky, helped by the fact this is a pretty good machine and you've doubtless stored it well.
I'd guess early Nineties, though others will be able to be more accurate. The old Fisher was a good machine, let down by that horseshoe-shaped idler that needed a full strip down to replace. We got quite good at it, but always insisted on fitting the opriginal Fisher part - pattern ones just wouldn't do. On later models they did what they should have done in the first place and made a cut-out in the sub-deck so it could be changed in minutes. |
10th Jul 2023, 2:50 pm | #3 |
If obtainable , I would at least replace belts and tyres.
10th Jul 2023, 3:03 pm | #4 |
Thanks. It strikes me the monitor I'm using is also from 1982. Again JVC... VHF/UHF... PAL and SECAM capable... in the old days used for colour DX'ing. The only trouble it ever gave was an o/c speaker.
10th Jul 2023, 3:44 pm | #5 |
The fact that VHS tapes like this can endure without noticeable degradation for 41 years prompts the question: could they last for centuries?
Steve
10th Jul 2023, 3:49 pm | #6 |
Some tapes last well regardless how stored, others just drop out and go mouldy.
BTW that JVC is a little cracker, I still have mine.
10th Jul 2023, 4:07 pm | #7 |
Although everything appears to be working well, check the tape carefully for creasing or tearing, especially if you plan to play tapes with sentimental value.
10th Jul 2023, 4:22 pm | #8 |
Your point is well made. Occasionally I have noticed a travelling 'ripple' down the picture, which I take to be mild tape creasing. I imagine this wouldn't be doing the heads much good, either.
Steve
10th Jul 2023, 4:46 pm | #9 |
The other point I'd make is to look very closely at the tape through the window of the cassette. Any white mould here means, unless valuable, the tape should be disposed of.
10th Jul 2023, 5:05 pm | #10 | |
Carefully check that your machine isn't causing any new damage, and the damage was pre-existing. A tip I would give you is to get in the habit of making sure the last operation before ejecting the cassette is FF or RW because if the idler is worn, there may be a loop of slack tape left after the machine unloads after a PLAY or REC operation.
-- Graham. G3ZVT |
10th Jul 2023, 5:24 pm | #11 |
Of course the other favourite is the pinch roller gone oval re damage.
10th Jul 2023, 5:25 pm | #12 | |||
Steve
10th Jul 2023, 5:42 pm | #13 | |
they don't even really fear cold or warm, but moisture is really the bad thing. so as long they're kept in living room, they can last. of course, always exception of bad binder chemistry. |
10th Jul 2023, 5:49 pm | #14 |
In this respect, the signs are good. This collection of tapes has lived on a shelf in the bedroom for the past 40 years, where it is always of a comfortable temperature and dry.
Steve
10th Jul 2023, 5:50 pm | #15 |
DO NOT use anything but IPA, plenty on Ebay or was last time I needed it.Plus lint free cloths.
12th Jul 2023, 8:13 pm | #16 |
From the looks of it, I think the HR-D180 would be from around 1985-1988.
