Old 23rd Jun 2023, 7:49 pm   #41
Helder Crespo
Helder Crespo's Avatar
Default Re: 405 from digital - for dummies
Originally Posted by paulsherwin View Post
Sorry, I deleted that post as unhelpful. See the eBay link in #4.
Also see this: https://www.ebay.co.uk/itm/HDMI-to-3...r/203223040077
This is what I use. Does the job well. HDMI from my laptop in, composite out and straight into the Aurora or Hedghog.
- Helder
Helder Crespo is offline
Old 23rd Jun 2023, 8:52 pm   #42
Panrock
Panrock's Avatar
It does seem that a laptop with a built-in screen has a crucial advantage over a PC - an unused HDMI port! Unfortunately my old H-P netbook doesn't though...
Panrock is offline
Old 24th Jun 2023, 6:25 am   #43
Panrock
Panrock's Avatar
Originally Posted by McMurdo View Post
Here's my solution for 'show me youtube on a 405 line telly'.
First - no computer needed. Source of stuff off the internet (any streaming video including youtube/vimeo/dailymotion/BBC iplayer/all-4/5OD etc) is a £30 'roku' box from Argos.
Thanks for this. The use of a separate dedicated unit is emerging as a clear alternative path to follow.
Another idea might be to convert the VGA output to 576i, if possible. Though since this wouldn't be a 'digital' source, it would probably be off-topic for this thread.
Steve
Panrock is offline
Old 24th Jun 2023, 10:05 am   #44
paulsherwin
paulsherwin's Avatar
Something like this will convert VGA to composite: https://www.ebay.co.uk/itm/Premium-C...k/354838316694
Beware of the very cheap passive converter cables - these require firmware support in the PC, which you probably don't have.
Kevin's non-computer solution is a good one. Roku or Firestick devices work well, and his converter box is a bit smarter than the other units linked in this thread and solves any aspect ratio problems.
paulsherwin is online now
Old 24th Jun 2023, 7:10 pm   #45
thermionic
thermionic's Avatar
Indeed….. you could just go with post 12 & 23 and save a lot of waffle, Steve!
The honesty of imperfection..........
thermionic is offline
Old 25th Jun 2023, 4:13 am   #46
Panrock
Panrock's Avatar
Well I feel my query has been very ably answered in this thread and I've learned a lot. Thanks to all for your contributions.
Steve
Panrock is offline
Old 10th Jul 2023, 6:54 pm   #47
Panrock
Panrock's Avatar
And I now have a working 'kit' based on the Roku solution. Thanks again.
https://www.radiocraft.co.uk
Panrock is offline
Old 13th Jul 2023, 1:51 pm   #48
Panrock
Panrock's Avatar
It does seem I'll need a Hedghog to chop off the sides and obtain 4:3 on 405-lines. The Roku box doesn't seem to provide any way to adjust the aspect ratio.
Whereas I can 'wangle' it in the above way for 405-lines, there doesn't seem any way I can do this for a 4:3 625-line picture for an older colour set.
Panrock is offline
Old 13th Jul 2023, 3:33 pm   #49
paulsherwin
Kevin's HDMI-composite converter box referenced in #40 appears to do cropping and zooming.
Old 13th Jul 2023, 4:02 pm   #50
Panrock
Panrock's Avatar
Yes, that indeed seems to be the solution! For this task, I am currently using one of the little £3.98 converters, which is amazing value but lacks the 'zoom' feature. Would Kevin kindly be able to let me know the ordering details of his unit?
Panrock is offline
Old 15th Jul 2023, 4:20 pm   #51
Tester.
...(hdmi) is converted via the adapter in the pics below. It has HDMI passthrough for a monitor TV and also outputs on SCART in RGB and Composite. It too needs a supply via a 5V wall wart, again any sort will do. Mine came from amazon. (the converter)...
Re/BIB, may I ask... ¿are we positive it outputs RGB via SCART? That would be kind of a first in this class of (Chinese) converters...
Tester. is offline
Old 1st Sep 2023, 3:25 pm   #52
Tester.
For future reference: I tracked down that ▲ specific converter, bought one myself and I can atest that it doesn't output RGB via SCART — it's composite video only.
(At least on its current iteration.)
Tester. is offline
