10th Oct 2012, 4:51 pm | #1 |
"power-up a transmitter" terminology
Long time ago, when the Morse key ruled, a transmitter was on, when the key was pressed down. In the broadcast world I think it used to be "bring the transmitter up". Now I hear talk of keying-up the transmitter. Did this come from the use of a different type of key or some other more interesting reason ? Cliff.
12th Oct 2012, 4:39 pm | #2 |
Re: "power-up a transmitter" terminology
Hi cliff,
Makes no sense to me either....probably American!
12th Oct 2012, 4:50 pm | #3 |
Almost certainly American - a lot of Military handbooks refer to a "Keying Line", or a Key socket.....
12th Oct 2012, 5:22 pm | #4 |
Don't UK professional broadcast engineers call them 'senders'?
12th Oct 2012, 5:33 pm | #5 |
12th Oct 2012, 6:04 pm | #6 |
Older amateurs refer to 'key down' to indicate transmission, which makes sense. Holding down the morse key makes the TX 'go'.
'Keying up' comes from the CB brigade.
Andy G1HBE. |
13th Oct 2012, 11:13 am | #7 |
I first came across 'key' or 'Tx key' as a reference to the pin, relay or line which causes the transmitter to transmit when I started as a comms engineer in the mid-70s. Prior to that I thought it referred to the active Morse key input, although I guess that causes the Tx to transmit too... It is more widely used on fixed eqpt rather than mobiles and portables, which tend to use PTT or Tx.
13th Oct 2012, 7:31 pm | #8 |
Those of us who deal with UHF/Microwave datalink transmitters are known to talk about 'defrost' for low-power test transmissions (usually into a dummy-load) and 'cook' for full-power operations.
A test dummy-load is sometimes nicknamed a 'chicken' - as in something-you're-going-to-roast. I'm also familiar with some Brazilians who were described as "sweating the klystrons" when they had antenna problems and so wound their uplink-power on a satellite circuit to rather more than the equipment was officially rated for. |
13th Oct 2012, 11:11 pm | #9 |
14th Oct 2012, 11:25 pm | #10 |
Thank you all for the replys, I find Sparkie67's pin/relay/line of interest as it appears there are more items than a Morse key to operate the transmitter. Another recent thread elsewhere on this forum, used the term " fire-up " the transmitter. Sounds like rocket-speak from the space race. So I just need to broarden my awareness of current technology. And for G6Tanuki and sweating the klystrons, I remember the aftermath of an exploded Klystron, all I could do was stand and stare. Cliff.
15th Oct 2012, 4:29 pm | #11 |
"Fire up" probably goes back to when TX's used valves and it took a while to get the Tx ready for full power. Like old valve TV's you needed to "warm them up" before getting a picture !! - oops another term has crept in now
15th Oct 2012, 5:24 pm | #12 |
I suspect "fire up" derives from the practice of lighting the fire to raise steam in a steam engine.
15th Oct 2012, 11:59 pm | #13 |
As you would with "Steam Radio".
With a transmitter of course you would tune for maximum smoke. I wonder if "Power up" has anything to do with transatlantic upside down switches?
