3rd Nov 2011, 7:07 pm | #81 |
Re: Transmitter type T1509A
More done to the 1509 today.
Connected to a bigger load and power meter, max ouptut is around 250W, there was no output on the lowest range - this appears to be due to a poor valve in the oscillator - once changed there was output. We also have modulation, there is a bias issue - the standing current will not drop below 75ma per valve - the -ve voltage will not go any lower than -36V, I suspect the selenium rectifier, and associated capacitors are well past their prime - I will build some modern replacement modules, one for the modulator, and one for the buffer/multiplier stage. The VFO/Oscillator calibration is out by a mile, this will need more investigation. It does appear to work quite well though, even considering the problems.
5th Nov 2011, 11:32 am | #82 |
I was just looking through the forthcoming VMARS members auction catalog, the only T1509 item listed was a control unit.
Steve M0SVB |
5th Nov 2011, 5:21 pm | #83 |
Hi Steve,
Is it a type 88 or a 310? Cheers Chris
BVWS, VMARS, RSGB, DEHS, RAOTA Nothings too big or too heavy, otherwise it wouldn't be where it is! |
8th Nov 2011, 4:31 pm | #84 |
Sean,
Don't forget I have a Type 310 control unit sitting in my kitchen waiting for you! Andy |
8th Nov 2011, 7:49 pm | #85 |
Hi Andy, not forgotten, Just awaiting a time when one of us are in your location!
Cheers Sean
15th Nov 2011, 9:41 pm | #86 |
Found out this photo taken probably 30 years ago for you Sean, of the late Vic Reynolds, G3COY, who was the radio instructor at an Air Cadet unit in Staffordshire for many years. Vic was a radio op on Hudsons during WW2 and built his ATC station around the 1154/55, with a later T1509 addition. Note the dummy load !
The equipment in the photo was fully operational and was used on the ATC HF National Net around 5MHz for many years, using the callsign VQ5X01. Happy days !! Last edited by Sparky67; 15th Nov 2011 at 9:49 pm. |
15th Nov 2011, 10:01 pm | #87 |
That can i say is a superb picture of real gear!
David GM8JET |
15th Nov 2011, 10:07 pm | #88 |
How interesting to see the picture of Vic, now S/K sadly.
That T1509 is the one that I bought for £200 from the ATC in Staffs a good many years ago. It was in near mint condition when I got it and after cleaning and polishing was probably the best one around. I used it on the vmars net and as you may imagine had very good reports from everyone. In 2004 I passed it on to someone who now stores it in a railway museum in or near Swanage in Dorest. I've lost contact with the new owner so it would be interesting to hear if anyone from the area knows of it. Jim |
15th Nov 2011, 10:43 pm | #89 |
What a great picture, and a superb shack!
Hope to get more work done on the 1509 soon - life has become rather busy at present! Cheers Sean
15th Nov 2011, 11:03 pm | #90 |
Sean,
any news of that ATU that was supposed to go with your T1509? Richard |
15th Nov 2011, 11:05 pm | #91 |
Ah, yes, the ATU.....
Er lets just say it wasnt the ATU for the T1509. Im still researching the history of the develpoment contract, so it may be a while until I have any more answers Sean
16th Nov 2011, 1:36 am | #92 |
..and just to add a bit more about the ATC T1509s... When these were first issued to the control and sub-control stations on the (then) three ATC HF networks (A (SK4B--), B (VQ5X--) and C (IQ8Y--)) most Sqns were in fairly old wooden huts, and those that had a 1509 issued had to build up the floor underneath to stop them either listing or going straight through RA17s were also issued to the control stations - quite a luxury in the 1970's.
And in 1976 or thereabouts I joined a small group of RAF ground radio bods and removed a T1509 from the Tx site at RAF Coningsby. All of us in one Land Rover, if I remember correctly !! Sparky |
3rd Apr 2012, 9:42 pm | #93 |
Hello Sean, Last we heard was "Hope to get more work done on the 1509 soon" then the trail went cold ! Cliff.
3rd Apr 2012, 9:47 pm | #94 |
Sorry Cliff - Lots has happened, but not so much on the 1509 - it resides at Chris's place (Onewatt) and access to the unit is a little tricky during the winter.
I think we are planning to get some more done and get it on the air within the next 2 months. Sean
4th Apr 2012, 10:34 am | #95 |
Thanks for the update Sean, it's an interesting project. C.
