Old 28th Jan 2006, 9:45 pm   #1
Tim
Tim's Avatar
Default Wander plugs?
Evening all.
Just found these on the Rapid electronics site.
I just wondered if one of the correct size could be used as a wander plug?
http://www.rapidelectronics.co.uk/rk...1794&XPAGENO=2
What does the team think?
TTFN
Tim
Tim is offline
Old 28th Jan 2006, 9:53 pm   #2
mikelect
mikelect's Avatar
Default Re: Wander plugs?
Hi Tim a good idea in principle, but to sub for a wander plug they would need to be 3.1mm or 1/8" and this doesn't appear in their size list.
Mike
mikelect is offline
Old 28th Jan 2006, 10:00 pm   #3
paulsherwin
paulsherwin's Avatar
Rather expensive as well in small quantities.
A standard phono plug will work if you flatten the pin a little.
Best regards, Paul
paulsherwin is online now
Old 29th Jan 2006, 1:29 am   #4
Tim
Tim's Avatar
Oh well, back to the drawing board.
Nearest size seems to be 2.8 mm dia.
Paul, your right about the price. I hoped that was for a pack!!!
Tim is offline
Old 29th Jan 2006, 1:12 pm   #5
AndiiT
AndiiT's Avatar
Hi
Maplins used to sell "proper" Wander plugs, I have had a look on their site and can't seem to find any though I will check the catalogue (far easier to navigate through IMHO) and let you know the part number if I find any in there
Andrew
AndiiT is offline
Old 29th Jan 2006, 1:55 pm   #6
stevekendal
stevekendal's Avatar
Maplins dropped them a couple of years ago and the last source, Tait components have run dry also Steve.
stevekendal is offline
Old 31st Jan 2006, 6:37 pm   #7
Mach One
Mach One's Avatar
Are these the same as Banana Plugs? They're 4mm I think.
Mach One is offline
Old 31st Jan 2006, 6:40 pm   #8
paulsherwin
Banana plugs are significantly bigger and won't fit. A number of manufacturers used banana plugs rather than wander plugs, notably Philips.
Paul
Old 31st Jan 2006, 10:30 pm   #9
stephanie
stephanie's Avatar
Which explains why regular banana plugs won't fit on my Ecko's antenna terminals...
Who was the braniac that came up with these weird-sized plugs? I'm going to have to try the mutilated-RCA plug-approach. I have some cheap ones I can cut the metal "shield off to just leave the pin.
stephanie is offline
Old 31st Jan 2006, 10:38 pm   #10
mikelect
mikelect's Avatar
It was probably someone from the former Colonies as my 1965 Heathkit Mohican has them for Aerial & Earth connections
Mike
mikelect is offline
Old 1st Feb 2006, 1:07 pm   #11
Mach One
Mach One's Avatar
It's a bit of a botch, but if you have some thickish braided mains wire (of the 13A variety), bare the end of the cable and fold it back, I find it fits into the Wander Plug (thinner) socket enough to get something working. If you're desperate...
Mach One is offline
Old 1st Feb 2006, 6:51 pm   #12
Telleadict
Having read trough this would it be possible to make a substitute for these plugs something like this.
Find a short piece of brass rod to fit the socket (anyone with a small lathe could easily turn something to fit),
Solder a length of flexible wire to one end of the brass rod.
Sleve the jointed end with some plastic tube and 'pot' with Araldite or similar to support the soldering.
I have never tryed this but it occered to me as I read this and if these plugs are no longer available it might be worth experimenting with
Full of good ideas, Will
Telleadict is offline
Old 1st Feb 2006, 7:36 pm   #13
DON THOMSON
Depends what you want them for but in the past I have used split pins with the wire soldered to the inside of the eye.You would need a non-corrosive flux to solder to steel.
Don
DON THOMSON is offline
Old 1st Feb 2006, 7:43 pm   #14
Nickthedentist
Nickthedentist's Avatar
If so, soldering would be easy, and a neat termination could be achieved with a bit of heat-shrink sleeving.
Nick
Nickthedentist is online now
Old 1st Feb 2006, 9:59 pm   #15
mikelect
mikelect's Avatar
You would need 3.2mm or 1/8" split pins which should be available. There is a guy called 6K8 on e-bay who usually has wander plugs and sockets, which are ex Govt. must be worth a try.
Mike
mikelect is offline
Old 1st Feb 2006, 10:32 pm   #16
Brian R Pateman
Brian R Pateman's Avatar
Matchsticks
Brian
Brian R Pateman is offline
Old 2nd Feb 2006, 12:00 am   #17
stevekendal
These look likely Steve http://www.jamestowndistributors.com...ss.Cotter.Pins
Old 2nd Feb 2006, 9:35 am   #18
Mike Phelan
Mike Phelan's Avatar
Hi Steve
Never seen brass split pins before!
Quite a few old wander plugs actually were split pins - steel, for springiness, and plated with nickel, I think.
This went into a threaded brass bush with a slot across it so the eye of the split pin went in and trapped the lead. The plastic surround then screwed everything together.
I would think that just using normal steel split pins, from Screwfix, Draper, local motor factor et al would be fine. You could use a - say - 6mm screw, drill it, slot it and saw the end off, then file or turn down an M6 nut and epoxy it together.
May try this - watch this space!
[IMG]http://static.***********/39/94439979_a853c0ae7e_o.jpg[/IMG]
Mike.
Mike Phelan is offline
Old 5th Feb 2006, 11:22 pm   #19
mikelect
mikelect's Avatar
For those interested in doing it the easy way wander plugs are available here http://cgi.ebay.co.uk/3MM-SPLIT-PIN-...QQcmdZViewItem HTH
Mike
mikelect is offline
Old 6th Feb 2006, 10:31 am   #20
Tim
Tim's Avatar
Blimey, I think it would be cheaper to make ones own.
A bloke up the road has a model engineering workshop, with lathe etc. I might take him a couple of beers.
Tim is offline
