Old 26th May 2009, 12:09 pm   #1
Royston
Default Roberts Radio R24 OFF/ON switch.
Hi Chaps
Just obtained a Roberts R24 Radio.
Sure enough the On/Off switch does not work. Looking at the switch I see it’s a DP/DT and the off contacts were not used. So I swapped the +9V and the two aerial wires to the contacts. The result is that the radio works fine. When the On/Off button is pressed down it’s off and up is ON
Quick and easy fix. I don’t have a circuit drawing of this radio so can’t see if there are any problems with this?
Regards Royston
Royston is offline
