19th Jan 2020, 2:14 pm | #1 |
Unusual intermittent fault cured
A small Japanese receiver, caseless, was in a box of 'assorted wrecks' I bought from a Radiophile auction some time ago. Before dismantling it, I thought I'd see if it was still functional. A few basics (battery, speaker, Deoxit on the volume control) allowed it to show signs of life (after the electrolytics had re-formed). But there was an annoying intermittent 'dying' effect, apparently caused by any slight movement. Obviously a loose connexion - battery snaps, vol control, solder joint gone off, etc.
A lot of searching, prodding, resoldering produced nothing. And then I noticed that the ferrite rod was expecially sensitive; yet its litz wires were soldered nicely in place with plenty of wiggle room. Then the penny dropped - the winding was resting on the volume control, and a sharp edge on the latter must be cutting thru' the litz insulation (see photo). A bit of judiciously-place insulating tape solved it.
Dave Teague |
19th Jan 2020, 2:52 pm | #2 |
Re: Unusual intermittent cured
I love fixes like this, I store the info in my head so when designing something I don't fall into the same trap.
19th Jan 2020, 5:37 pm | #3 |
Re: Unusual intermittent fault cured
Tut! Tut! Not like you to miss that Dave! (I'll have to pop 'round and supervise you a bit more often!!)
Red to red, black to black. Throw the switch and stand well back! |
19th Jan 2020, 6:06 pm | #4 |
'like'.
19th Jan 2020, 7:36 pm | #5 |
This is spooky - about a year ago there was yet another thread about replacing Ge devices with Si and I looked for a scrap simple set to take some measurements, and in a box of 'assorted wrecks' there was the PCB from an unknown Japanese pocket portable with no case which I had found years ago. An early 6-transistor 'AM-only' set with transformer-coupled push-pull audio output for speaker or earphone. Exactly like yours Dave. The only indication of brand or model was the legend SRV-62 on the tuning knob.
I'd not done any repairs for so long that I needed to ramp up my practice, starting on something very simple, like this. Applied 9V and clicked the volume control 'on' - dead short. Fair enough, I was expecting some leakage on those 60-year old electrolytics and maybe the O-P transistors so I started pulling them out. Still dead short. The supply line goes only to an electrolytic, the oscillator coil, and some resistors, so I pulled out the coil/transformer and checked for shorts to the can. None. Beginning to despair I put an ohmmeter across the supply line, it was virtually O/C - until the vol ctrl switch was clicked 'on'. 'How did that happen' you might ask (well I did) so by cutting tracks in the supply line it turns out that the switch shorts to the track earthy end when on. The bits went in a box for another day. Let's compare our two boards
- Julian It's good here |
19th Jan 2020, 11:59 pm | #6 | |
You're most welcome Tractionist! The teapot's always full (even though the biscuit tin may not be).
Dave Teague |
20th Jan 2020, 12:04 am | #7 |
As you say, uncanny - but I think that they're actually different models (but with a certain 'family likeness ) In mine: there's a gap between the tuning cap and the first IFT; in yours there isn't. But both fail in having the tuning coil almost/actually resting on the volume control & on-off switch.
Dave Teague |
20th Jan 2020, 11:13 am | #8 |
Good one.
20th Jan 2020, 12:07 pm | #9 |
Well done for finding the fault, they are sometimes far from obvious!
My most perplexing fault was a bad pcb track whick looked OK but measured several K ohms.. upon close inspection it had a spot of mild discolouration - something attacked the copper - of course, a simple wire link fixed it.
...where on earth did that spring/screw go?? |
