Old 19th May 2019, 10:25 pm   #1
GrimJosef
Default Simple reformer for HT capacitors in valve-rectified equipment
The forum has had quite a few descriptions of reformers for electrolytic capacitors posted in the past. The circuits generally consist of two parts - a DC power supply of appropriate voltage, and something to limit the current so the capacitor's insulating layer has time to reform before the voltage gets high enough to punch through and permanently destroy it.
I've put together a simple circuit which plugs into the rectifier socket of a piece of equipment and allows the existing mains transformer to be used as part of the DC power supply. The current limiter consists of just three series resistors, two of which can be shorted out by a rotary switch to maintain the reforming current at a reasonable value as the capacitor charges and the voltage difference between the supply and the capacitor falls.
As well as making use of the mains trasformer, connecting via the rectifier socket also allows the HT capacitors to be reformed in situ, so obviating the need to disconnect and reconnect them. Another advantage is that this reformer also carries out a simultaneous high-voltage insulation test of any other components connected to the HT rail.
The circuit diagram is shown in the first picture. The black wiring is the reformer itself, the red shows what it's connected to via the rectifier socket. It uses components I happened to have to hand, so values haven't been tightly optimised. It was designed to deliver a low reforming current - less than a milliamp - since in my experience such very gentle reforming hardly ever overcooks the capacitors. The DC supply consists of two 1N4007 rectifiers, a 1uF reservoir capacitor and a series resistor/Zener diode chain feeding a 33uF smoothing capacitor. This chain forms a potential divider with the smoother's 390k bleed resistor, the division ratio setting the maximum voltage that the downstream capacitors will be reformed to. This matters because the combination of an off-load transformer and solid-state rectifiers with low forward voltage drop would otherwise raise the reforming voltage far beyond what the HT capacitors are used to.
The Zener diodes are small, which is helpful given that I wanted to house the whole circuit in a package compact enough to fit where a valve rectifier normally goes. But some resistance is needed both to reduce the ripple current into the smoother and also to allow the division ratio to be easily adjusted. This particular circuit was set up for reforming the capacitors in a (pretty scruffy) Quad II amplifier, where the HT rail is usually in the region of 360-385V, depending on the mains voltage, the condition of the rectifier and whether we are measuring before or after the amp's smoothing choke. The resistance needed to deliver this voltage turned out to be 27k.
The second picture shows the reformer in use. It's housed in a stack of 40mm solvent-weld PVC pipe fittings with a scavenged octal valve base glued into the bottom and a screw-fit inspection cap on top. The latter serves as a mount for the rotary switch and also allows the circuitry to be inserted and removed if/when necessary. There are three 4mm sockets for metering the capacitor voltage and the reforming current (via the voltage across the 36k final charging resistor). In the picture this current is 0.23mA (8.24V/36k) with the Quad II's 16uF reservoir and smoothing capacitors charged to 253V. You can see the reformer's ground connection made via a trailing lead into one of the speaker sockets.
I chose valve era resistors (mostly Piher 1W ones) since these are rated for typical HT voltages. The exceptions were the two 18k current limiting/sensor resistors which are 5W wirewounds. In the event of an HT rail short to ground at maximum voltage, when the rotary switch would probably have taken all the 220k resistors out of circuit, I wanted the 18ks to last long enough for me to notice the fault and switch the power off. 375^2/36k is about 4W which shouldn't fry the wirewounds too quickly, even given the limited ventilation provided by a few air holes round the back of the PVC pipe.
Cheers,
GJ
Name:	Octal cap reformer small.jpg
ID:	183433   Click image for larger version
Name:	Octal cap reformer Quad II small.jpg
http://www.ampregen.com
GrimJosef is online now
Old 19th May 2019, 11:36 pm   #2
Refugee
Refugee's Avatar
Default Re: Simple reformer for HT capacitors in valve-rectified equipment
That is a posh version of what I do.
The 1N4007 anode goes directly into a safe block that is plugged into the isolating transformer. The negative of the 10uf capacitor goes into the other side of the safe block.
The resistor arrangement is 2 200K 2W resistors with crock clips to add the second resistor in parallel with the first one. The connection is to the rectifier cathode.
This way you can even leave the valves in the amplifier.
I always check the G1 voltages and select any replacement capacitors while reforming is in progress.
Refugee is offline
Old 20th May 2019, 9:48 am   #3
GrimJosef
The real change for me was being able to use the unit's own mains transformer, so I could get the reforming voltage I needed without having to sort out a separate supply.
In a cold Quad II (no valves powered) in situ reforming would put the full HT voltage across the Hunts interstage coupling capacitors. These were only rated for 350V when new and they're notorious for going leaky after 50-60 years, even though they only see 100-150V in service. It's not worth risking destroying them with the reformer, and their leakage current might well confuse the situation when I'm trying to check the HT electrolytics. Since I'm almost certainly going to replace them anyway I just detach one end of them before I start.
Cheers,
GJ
Old 20th May 2019, 1:20 pm   #4
Refugee
Refugee's Avatar
My idea is that the G1 caps hold the voltage down in the early stages of reforming. Fitting replacements works in the same way as reducing the dropper resistor value.
Refugee is offline
