Old 3rd Nov 2018, 4:16 pm   #1
buggies
buggies's Avatar
Default Temporary load for power supply testing
Needed to test a 5 volt 20 amp power supply was working at full current and had no suitable resistive load. Google lead me eventually to a 3 minute youtube video:-
https://www.youtube.com/watch?v=WECW88rJYrE
Using some scrap 0.7mm O/D (and some 0.4mm) enamelled copper wire I was able to dump the 20 amps and later 35 amps as a test of a transformer.
ID:	172064   Click image for larger version
ID:	172065   Click image for larger version
George
buggies is offline
Old 3rd Nov 2018, 6:41 pm   #2
Herald1360
Herald1360's Avatar
Default Re: Temporary load for power supply testing
Somewhat more sophisticated is a length of stainless steel thin wall tube between a couple of hoses with water flow through. Electrical connections can be via big crocodile clips or a bit better, worm drive hose clips.
Don't forget to turn on the water..... hoses blowing off red hot tube in a cloud of steam is a bit lairy
5l/min water and 60C rise is good for 20kW.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 4th Nov 2018, 4:57 am   #3
M3VUV51
In a similar vein I needed a high wattage resisistor for the current sense input of a 723 based PSU I'm homebrewing. I needed 2 ohms, in the end I used part of an old electric fire element. I just bolted a wire to one end then used a hose clip with a wire attached and slid it up and down the bar until I got the resistance I needed. It works perfectly, also heat proof and easy to mount.
M3VUV51 is offline
Old 4th Nov 2018, 5:34 pm   #4
G6Tanuki
G6Tanuki's Avatar
Cunning!
In the past I've used a coil of galvanised-steel agricultural fencing-wire to make a 48VDC dummy-load; dunk it in a (plastic) bucket of water and it can dissipate a few hundred Watts for quite a long time (I ran it overnight and only a bit of the water boiled away).
Old car headlamp bulbs are also good - I get H4 (main/dip beam) bulbs with one dead filament for free from my local friendly garage. Wire a bunch of these in series/parallel and you can easily get to 500 Watts dissipation.
G6Tanuki is offline
Old 4th Nov 2018, 5:51 pm   #5
TonyDuell
6V car bulbs (not easy to find, but they do exist) make good dummy loads for 5V power supplies. I've used 1 or 2 6V headlamp bulbs with the fillaments in parallel as a dummy load on a minicomputer PSU I was rebuilding.
TonyDuell is online now
Old 4th Nov 2018, 7:49 pm   #6
G6Tanuki
G6Tanuki's Avatar
6V bulbs persisted a lot longer in the world of motorcycles.
G6Tanuki is offline
Old 4th Nov 2018, 11:10 pm   #7
bikerhifinut
Still very much available.
https://www.mandp.co.uk/motorcycle-s.../standard.html
Probably even halfords too but you'll need to order them these days.
A.
bikerhifinut is offline
Old 6th Nov 2018, 2:58 pm   #8
Andrew2
Andrew2's Avatar
I use the same method. And they light up when 'on' which is always handy.
Andy G1HBE.
Andrew2 is offline
Old 7th Nov 2018, 6:40 pm   #9
hannahs radios
One bit of advice I'd give if you're using lamps as a load is it's a good idea to have them switched so you can bring them on one or two at a time because the inrush current might make the PSU shut down because the cold current is many times greater than the hot current. Just an extra precaution worth taking especially with some picky SMPSUs.
hannahs radios is offline
