Old 10th Feb 2021, 10:59 am   #1
jonnybear
jonnybear's Avatar
Default Neon EHT Indicator wand.
Neon Indicator wand useful item, quick checking for eht, lcd backlight inverter safely, all you need is a 5mm dowel I used a lolly stick neon bulb and a piece of shrink sleeve,
cut a angle with junior hacksaw fit neon in groove and finish with shrink sleeve.
Keep in pencil drawer one day it may be useful.
ID:	226410   Click image for larger version
ID:	226411   Click image for larger version
ID:	226412   Click image for larger version
jonnybear is offline
Old 10th Feb 2021, 12:17 pm   #2
Julesomega
Julesomega's Avatar
Default Re: Neon EHT Indicator wand.
In principle fine, but don't try it on the mains
Wouldn't it be worth adding a 220k resistor in series, it will still light up nice and bright with EHT
- Julian
It's good here
Julesomega is offline
Old 10th Feb 2021, 1:13 pm   #3
jonnybear
jonnybear's Avatar
It will not work on the mains as it is totally isolated no path to earth, fitting a 220k resistor would make it dangerous giving it a path to earth via your body, not good when prodding around eht items. the neon lights on proximity.
Old 10th Feb 2021, 1:19 pm   #4
factory
This was a technique recommended in older Tek oscilloscope manuals for checking the high voltage oscillator was running, the neon was placed against the glass envelope of the oscillator valve, though in the picture it is held without a stick.
factory is offline
Old 10th Feb 2021, 1:36 pm   #5
Nuvistor
Nuvistor's Avatar
Had one in my tool kit, well worth it for checking around the EHT in TV sets.
Frank
Nuvistor is offline
Old 10th Feb 2021, 1:41 pm   #6
jonnybear
jonnybear's Avatar
I know it is an old technique, I was just using odds and ends lying around, I used it to detect if inverter was working on laptop, did not fancy holding neon by the wires, seeing what happened to an apprentice years ago when he stuck a neon screwdriver into a insectocuter to check it was working, his reaction showed everyone in the room it was.
Old 10th Feb 2021, 1:47 pm   #7
Julesomega
Julesomega's Avatar
You're saying it works on DC?
Intriguing, what sort of minimum voltage do you need to light a disconnected neon?
- Julian
It's good here
Old 10th Feb 2021, 1:47 pm   #8
Dave Moll
Dave Moll's Avatar
Originally Posted by jonnybear View Post
...did not fancy holding neon by the wires, seeing what happened to an apprentice years ago when he stuck a neon screwdriver into a insectocuter to check it was working, his reaction showed everyone in the room it was.
As long as it didn't become an apprenticocuter!
Dave Moll is online now
Old 10th Feb 2021, 4:08 pm   #9
I used to have a similar "Dipstick" for testing whether there was RF present in transmitter/ATU 'tank' circuits - mine used a NE-2 type Neon with its legs extended by a couple of inches of wire, fitted into the end of a clear Polystyrene tube about two feet long.
MF/HF power made it glow orangey; VHF gave an impressive purple!
Old 10th Feb 2021, 4:28 pm   #10
ex 2 Base
I'm sure readers will already know, a simple way to test on a micro wave cooker is to mount a neon with both lead bent outwards (antenna) using some Blue tack and a glass of water. As the plate rotates the neon flashes on and off
ex 2 Base is offline
Old 10th Feb 2021, 7:26 pm   #11
CambridgeWorks
CambridgeWorks's Avatar
Used to tape just the glass neon on tip of vhf 2 way radio aerials on my works van. Nice purple glow.
Toy, really, soon fell off and never replaced.
Rob
Apprehension creeping like a tube train up your spine - Cymbaline. Film More soundtrack - Pink Floyd
CambridgeWorks is offline
Old 10th Feb 2021, 8:04 pm   #12
Dave Moll
Dave Moll's Avatar
Surely, a purple glow requires argon. Neon gives an orangy pink.
Old 10th Feb 2021, 8:28 pm   #13
Dig out a decently-powerul VHF transmitter, hook up a dummy-load, dangle your neon glowbottle into its PA and hit transmit.
You'll get purpleness.
Trust me on this.
In times-past the colour-of-glow from your neon-dipstick was a reliable indication of whether the parasitic-oscillations in the amplifier-you-were-debugging were VHF or LF.
Old 10th Feb 2021, 10:31 pm   #14
ChristianFletcher
ChristianFletcher's Avatar
This looks a fun little project I like gimmicks like this. I remember back in the day it was possible to buy some impressively large neon lamps. The little modern ones do look a bit sad. Thanks for posting.
Regards Chris
Every Silver Lining Has Its Cloud https://youtube.com/channel/UCvBpiuUUnErJlNBm6DWb3Ww
ChristianFletcher is offline
Old 10th Feb 2021, 11:08 pm   #15
Dave Moll
Dave Moll's Avatar
Trust me on this.
Thank you for enlightening me on this.
