Old 6th Apr 2019, 3:36 pm   #1
jonnybear
jonnybear's Avatar
Default SMD Hot Air Soldering SMD Jig
Finding the tiny SMD components tend to blow away when trying to rework with hot air station, + getting older and a little bit shakier trying to use tweezers, I made up this little device out of old bits and pieces laying around. length of brass brazing rod a bit of copper 15mm pipe and a little bit of lead. works a treat.
ID:	180962   Click image for larger version
ID:	180963   Click image for larger version
ID:	180964   Click image for larger version
jonnybear is offline
Old 6th Apr 2019, 8:48 pm   #2
60 oldjohn
Default Re: SMD Hot Air Soldering SMD Jig
Good idea, I think every one has their own method. I used one of the cable ties that come with new appliances. That's the plastic ones with the wire down the middle, dip the end in a little flux and the transistor can be picked up, placed and held in place. I should add I use a soldering iron and not hot air
John.
60 oldjohn is online now
