Old 25th Mar 2023, 8:02 am   #1
rafalow
Default Power connector Marantz CDR 1
In an older thread I asked for help finding a replacement for the
Power connector Marantz CDR 1.
I am still searching to find a good deal.
recently I found this version of the schaffner power connector.
schaffner fn379b-2-31
I need the schaffner fn379b-2-22 , the 22 refer to the fuses i think.
But I can not find any info about the schaffner fn379b-2-31 version.
In the datasheet is no info about the 31 version.
Is there anyone that has some info ??.
kind regards
rafalow
rafalow is offline
Old 25th Mar 2023, 11:15 am   #2
ronbryan
Default Re: Power connector Marantz CDR 1
Have you tried contacting Schaffner at https://www.schaffner.com/contact to ask them to explain what a -31 fuse holder is. My understanding of these filters is that the fuse carriers are interchangeable between 1.25" and 20mm, but Schaffner should be able to advise about the -31.
Ron
ronbryan is online now
Old 25th Mar 2023, 12:51 pm   #3
rafalow
Thank you,
I will contact schaffner.
Kind regards
rafalow is offline
Old 25th Mar 2023, 1:06 pm   #4
G6fylneil
Looking at the picture of the voltage selector I think that may be a 115/230 version of the voltage selector. But you can use the voltage selector "drum" out of the old one. They are just "coded" and marked differently. The filter is common to both. Hopefully Schaffner can advise. I think they will soon become obsolete, nothing has mains transformers these days.
G6fylneil is offline
Old 25th Mar 2023, 3:20 pm   #5
rafalow
Thank you,.
I also thought it has something to do with the selector.
now I am searching for a link to ask the queation to schaffner.
even that is a struggle, can not find a direct email link with technical questions.
only forum support.
kind regards.
rafalow is offline
