2nd Oct 2012, 9:19 pm | #1 |
KW2000B valves.
Hello,
Just have this tranceiver: Two tubes are very strange to me. x13 x12 One says Brookes 456.46 8/71, the other is partly readable Brookes 64 0/70. What is the purpose of these tubes? All info is welcome about this trx. Regards carlos Last edited by Mike Phelan; 3rd Oct 2012 at 9:18 am. Reason: Correct typos. |
2nd Oct 2012, 10:16 pm | #2 |
Re: kw2000 b tubes
They are quartz crystals? Probably carrier oscillators.
2nd Oct 2012, 10:19 pm | #3 |
Re: kw2000 b tubes
I don't know much about KW's but I do know Brookes made quartz crystals - abbreviated as Xtal - which these sound like especially as you refer to X12 & X13 which again would indicate (X)tal to me. Last clue is the marking 456.46 - this is the frequency in KHz and 8/71 will be August 1971. Lots of xtals were made in glass holders the same size as B7G. PLEASE don't apply any high voltage to these !
John G3VUO |
2nd Oct 2012, 10:59 pm | #4 |
Re: kw2000 b tubes
Probably best you download a manual before applying power to the set. The items are the USB and LSB carrier crystals as already stated.
3rd Oct 2012, 11:59 am | #5 |
Re: KW2000B valves.
thanks to all,
the trx has been fired up already with variac, its working but need a major cleaning and revision, the dial is slipping, so if anyane has experience with this dial................ regards carlos |
3rd Oct 2012, 5:41 pm | #6 |
Re: KW2000B valves.
lots of help on, Yahoo group KW_Radios Cliff.
3rd Oct 2012, 7:32 pm | #7 |
Re: KW2000B valves.
5th Oct 2012, 3:51 pm | #8 |
Re: KW2000B valves.
hello, this guy sells jackson balldrives,
i need this for the kw2000 tranceiver Mainline Electronics 192 Little Glen Road Glen Parva Leicester LE2 9TT UK http://www.mainlinegroup.co.uk/jacksonbrothers/4511.htm but email is bouncing back, still in buisiness? THANKS CARLOS |
5th Oct 2012, 4:06 pm | #9 |
Re: KW2000B valves.
No idea, but it might be worth a phone call:
192 Little Glen Road Leicester England LE2 9TT sales@mainlinegroup.co.uk 0116 278 0980 so from abroad.... +44 116 278 0980
