20th Sep 2012, 3:08 pm | #1 |
Crystalling Pye PF85's.
Does anyone know the formula for the receive crystals in Pye (Philips) PF85 PMR sets? I have a pair of marine vhf sets arriving soon (Band A1 or B2), each set up on marine channel 69. I'd like to move them up to 162.025 mhz and take off a tap at the discriminator for decoding maritime AIS data.
Many thanks and kind regards, Robert B.
Real radios glow in the dark M6GLD |
20th Sep 2012, 5:28 pm | #2 |
Re: Crystalling Pye PF85's.
This might help. When you get them, look at what sort they are and then come back if needed.
http://home.wanadoo.nl/pmpc/PFX_Series.htm Cheers, Steve P.
20th Sep 2012, 7:31 pm | #3 |
Robert,according to Chris Loreks PMR Conversion book PF85 A1 and B2 sets receive crystal is :-
Crystal Freq= (receive freq-10.7 Mhz)/3 so thats (162.025-10.7)/3 = 50.4417Mhz. Hope that helps.
Dave G1AGK. My perception is my reality! |
20th Sep 2012, 8:16 pm | #4 |
I would ring Quartslab to ask and order from. They are pretty good at this sort of thing.
20th Sep 2012, 8:27 pm | #5 |
Despite a 30-year history of recrystalling numerous Pye Cambridges/Vanguards/Westminsters/Whitehalls/Europas onto 144MHz, and having also earned my living for half-a-decade installing the Pye "MOULD" Pegasus-type radios, these days to be honest it just doesn't make sense to bother with rock-bound surplus PMR gear.
A couple of crystals cut to your intended frequency will probably cost more than a 'budget' chinese frequency-synthesized transceiver from the likes of wouxon or Feidaxin. |
20th Sep 2012, 11:38 pm | #6 |
Or even a Baofeng for £30 or less.
But it is economically viable, for receive only, on one channel on two identical high-quality ex-PMR units, which I think was what Robert B. was intending? |
21st Sep 2012, 11:00 am | #7 |
Indeed, there are two AIS frequencies on which vessels transmit identity and position data, and being in Falmouth I thought I'd give it a go. I've tried taking the audio output from a synthesised RX to my soundcard for decoding, but this is resulting in a high percentage of errors. For packet data work a discriminator tap is more reliable, and I don't wish to modify this rig (or tie it up on AIS when it's often used as a general 2 meters monitor).
It also helps that I already have a PFX and PF85 on 70cms and a charger to accompany them, so a new pair of batteries are worth the £5 each they cost me. Getting a pair of crystals cut will be less than the cost of buying a new receiver (and potentially wrecking it trying to tap the discriminator) and far less than even a "budget" professional AIS decoder (prices start around £100). Many thanks for the crystal data, I shall report back as this proceeds. Regards, Rob
29th Sep 2012, 9:38 pm | #8 |
Further to the above, the sets have arrived and both appear to be in good shape. The batteries are recent replacements and hold their charge well, which is a nice bonus.
One shall be crystalled for AIS reception here. The other I should like to crystal for channel 16 under my portable marine licence. I assume the transmit frequency for these is F/9, i.e. for 156.8 = 17.4222. I'd be greatful if this could be confirmed. My thanks and kind regards, Robs
30th Sep 2012, 8:32 am | #9 |
Not quite Rob, according to the same source as post#3 the A1 and B2 transmit is f/8 (the uhf versions are f/9) so for 156.8, Xf= 156.8/8=19.6Mhz.
Both Chris Lorek's books are a must if you are into modifying ex PMR stuff. (no connection just a satisfied user)
5th Oct 2012, 10:19 pm | #10 |
I think I've got a PF85 service manual lurking about somewhere if you need more info.
Alan. |
