Old 10th Nov 2005, 8:53 pm   #1
geoff Andrews
Default GE BRT 400 Receiver
I have just aquired myself a BRT400 complete with operating hand book.
First thing I did was to check out all the voltages and supprise, supprise an almost totaly different valve line up from manual. This has been done either in manufacture or a major re-build. Valve line up 6BA6's 6BE6 6AM5 6AT6 6AM6. Can anyone tell me please what I have and if there is a schematic any where for this receiver?
Geoff.
geoff Andrews is offline
Old 11th Nov 2005, 9:47 pm   #2
Ed_Dinning
Default Re: GE BRT 400 Receiver
Hi Geoff, I've been promised one of these sets next month so I can give you some details then. I do have a manual at present. This is RCH.1001/8 and has the valves listed as : W81, X81, N77, DH81, D63, KT81, Z77, S130, U52, (multiples of some types).
The manual runs to 40 or so pages, your valve numbers seem to be about equivalents. PM me and I'll see if I can get you a scan of the circuit.
Best regards, Ed
Ed_Dinning is offline
Old 11th Nov 2005, 10:24 pm   #3
geoff Andrews
HI Ed, thanks for reply and offer of CCT. The valve line up you mentioned is as my manual, it's just the RX itself that differes! Receiver goes very well and I am pleased with mine, hope you enjoy yours
Regards
Geoff
Old 11th Nov 2005, 10:31 pm   #4
jim_beacon
jim_beacon's Avatar
Geoff,
there are two basic versions of the BRT400, one with Loctal valves (which you have the manual for), and one with minature valves, which you have.
The loctal valve version has problems, mainly with stability, which was cured in the later version - we had both at work, and the earlier versions were generally hated!
They are, when in good order, a nice receiver, and easy to use. The filtering is good enough for CW work, and they will resolve SSB. They also look good with the chrome trim and large "slide rule" dial.
Best of luck with the repairs
Jim.
jim_beacon is offline
Old 14th Nov 2005, 1:48 pm   #5
Biggles
I've got one of these, a BRT402, with miniature valves. It was a good receiver until the final IF transformer went s/c primary to secondary. It's a multi tapped complicated affair for variable selectivity so it's not going to be easy to find a replacement. It's been on the "to do" pile for about 15 years now, so it's not looking good for a repair!
Biggles.
Biggles is offline
