9th Sep 2005, 8:07 pm | #1 |
Eddystone 680x, how to dismantle
I recently acquired the above receiver in good working order but would like to clean the tuning scale and glass etc. Having taken the case off the unit, it looks very difficult to get to this area. Is it as difficult as it looks? should I bother, it's not that dirty?
9th Jun 2006, 9:51 pm | #2 | |
Re: Eddystone 680x, how to dismantle
9th Jun 2006, 10:26 pm | #3 |
I think all Eddystones are similar. I have fully dismantled and repaired my 770R tuning drive, yes it wasn't easy.
You must remove the knobs which is not so easy on the 770R unless you know that the turret knob is held on by a tapered pin that is locked by the grubscrew, but the 680 is probably quite different (and easier). If you do encounter the tapered pin just realise that it is easy to remove if you drive it out using a panel pin, but only in the right direction. The trick to removing the front panel is to realise that it is all held together by the bolts that hold the front handles on. Unscrew these, noting that the big spacers will fall out as you remove the bolts. There is one other rather curious bolt that must be undone somewhere in the middle area - you just remove the nut from it. The last difficulty is that you have to release all the pots and switches from the panel. |
