Old 22nd Jul 2008, 9:52 pm   #1
GJR 11L
Default Brasso for wood!
I'm not sure whether this has been put forward on the forum at some earlier time as a means of removing scuffs and making wooden cabinet parts nice and shiny once more, but I can't believe that I'm the only person to have done this:
The Hacker RP75 MB that I just posted up in "Success Stories" had wooden end pieces that were frankly in a shocking state, their one saving grace being thet no large chunks were missing from them. So, by pure chance and the proximity of my pot of Brasso wadding, I tried the product on the wood, which was so far gone that only covering their surface with some sort of dye or even thin paint would have been a viable alternative.
Long story short; it worked, rubbing the timber with the wadding and then, as when using it on anything else, polishing off with a soft duster, brought the wood up very well indeed. The little scratches and scrapes vanished, and are , two days after treatment, still not visible and the effect is very satisfactory.
Try it, I did so because there was nothing to lose, but it really works!
John.
GJR 11L is offline
Old 22nd Jul 2008, 9:57 pm   #2
paulsherwin
paulsherwin's Avatar
Default Re: Brasso for wood!
A cutting compound such as T-Cut will have a similar effect. It's always worth trying something like this before doing anything more drastic.
Paul
paulsherwin is offline
Old 23rd Jul 2008, 5:51 pm   #3
chipp1968
chipp1968's Avatar
one word of caution . with these products that leave a white compound on drying , be aware of opend grain woods like oak. Its very difficult to remove it rom the grain.
chipp1968 is offline
Old 24th Jul 2008, 1:20 am   #4
Darren-UK
I wondered about this too. Liquid Brasso certainly would do this but what about wadding? This is far less 'liquidy' than the former.
Darren-UK is offline
Old 24th Jul 2008, 9:03 am   #5
dseymo1
I use Rustins Finish Reviver for this sort of thing. It's similar to Brasso or T-cut, being mildly abrasive, but is formulated for wood finishes, and gives excellent results with little effort. Any residue is water soluble and very easy to remove.
It also works well on plastics, but caution is required - enthusiastic polishing can generate enough heat to melt the surface of some types, and the reviver can become trapped in the melted layer, causing staining.
dseymo1 is offline
Old 24th Jul 2008, 12:12 pm   #6
GJR 11L
This was the wadding, and no white streaks are evident even now, another few days after I did the job. I don't think it would be any more likely to stain than Topps and is even more effective at hiding little scratches than that stuff.
Here closer shots of the ends of the Super Sovereign that was treated with the wadding:
ID:	18703   Click image for larger version
John.
GJR 11L is offline
Old 24th Jul 2008, 5:50 pm   #7
mastermanx2001
Sorry to butt in, how about Teak oil, I have found it do a wonderful job covering up scratches etc.
mastermanx2001 is offline
Old 24th Jul 2008, 9:18 pm   #8
paulsherwin
There are lots of finishes which will cover up scratches, but this thread is about rubbing off light scratches using Brasso and other cutting compounds.
Danish oil is often used as a finish which will also hide scratches. I often use the Colron range of dyed wax finishes.
Please stay on topic folks.
Paul
Old 24th Jul 2008, 9:29 pm   #9
mastermanx2001
I thought this topic was about scratches, wow it's like being back at school.
Old 24th Jul 2008, 9:35 pm   #10
Brian R Pateman
Brian R Pateman's Avatar
Actually the topic is "Brasso for wood."
No mention of scratches, a subject on which there are many other threads.
Brian
Brian R Pateman is offline
