14th Jun 2021, 5:24 pm | #1 |
Bournemouth 2 metre repeater.
Hi anyone know the tx/rx frequency and ctss tones for the 2mtr voice repeater serving Bournemouth thanks Mick
14th Jun 2021, 5:31 pm | #2 |
Re: bournemouth 2 mtr repeater
14th Jun 2021, 8:48 pm | #3 |
Re: Bournemouth 2 metre repeater.
In normal times you might also expect to be able to work the Poole 2m repeater:-
GB3PB TX:145.6250MHz RX:145.0250MHz Type: AnalogueVoice CTCSS: 71.9 However this repeater is currently (June 2021) listed as... NOT OPERATIONAL |
15th Jun 2021, 12:04 pm | #4 |
Nice to see Metre used correctly..... I Hate the mis spelling (meter)..Grrrr
A meter is used for measuring........ a metre is a measurement of distance..... I guess our "friends" over the pond, couldnt work it out
Should get out more. Regards Wendy G8BZY Last edited by Wendymott; 15th Jun 2021 at 12:06 pm. Reason: Additional text |
15th Jun 2021, 2:03 pm | #5 |
Alot play safe and apply to Mtr or M,but I was reading an article in the paper the other day that they are considering a return to imperial measurements! Great so every thing in chinese soon then?
15th Jun 2021, 5:19 pm | #6 |
The metre unit is m (lower case), imperial units are metric one inch being defined as 25.4mm. Over the pond they use English units, somewhat different.
17th Jun 2021, 11:46 pm | #7 |
If I ask for a pint over the other side of the pond, I only always get short measure - 16 fl.oz. instead of the full 20!
Cheers - Martin ZL2MC |
18th Jun 2021, 9:02 am | #8 |
As the OP's question has been answered and the thread has drifted off into a discussion about units of measurement, it's time to close this thread.
