Old 16th Feb 2021, 10:10 am   #1
Denis G4DWC
Default BNOS LPM144-180-10RF RF Power Amplifier Problem.
An elderly Amateur radio friend has a BNOS LPM144-180-10RF Amplifier. As far as he is aware this is the 180W version of the more common 100W unit.
As an RF amplifier it works OK but he needs to disable the internal VOX as he has a sequencer to make sure the masthead GASFET receive Amplifier is safe before showing it 180W!.
He can't see any obvious way of disabling the VOX facility. It would of course be possible to trace out the circuit out but the tracks are on the underside of the PCB and would require removal of the expensive RF devices which, understandably, he's reluctant to do.
Does anyone have a circuit diagram of other details that would help.
Thanks
Denis
If you take something apart often enough, eventually you'll have two of them....
Denis G4DWC is offline
Old 16th Feb 2021, 10:23 am   #2
Terry_VK5TM
Terry_VK5TM's Avatar
Default Re: BNOS LPM144-180-10RF RF Power Amplifier Problem.
There's a schematic of the 100W version here, hopefully the RF switching circuit is the same
https://www.george-smart.co.uk/wordp..._Schematic.png
Terry VK5TM
https://www.vk5tm.com/
Terry_VK5TM is offline
Old 16th Feb 2021, 11:45 am   #3
Steve G4WCS
Steve G4WCS's Avatar
The amp can be hard switched bia a 0v ptt on a jack socket on the rear. Presumably inserting a jack socket disables the rf switching
http://www.staffordengineeringsystem...3-100%20OI.pdf
Steve G4WCS is offline
Old 17th Feb 2021, 11:46 am   #4
Denis G4DWC
Hi Terry and Steve
Thanks you so much for the information which I passed on yesterday.
The PTT Jack socket is only a two pole component and doesn't disable the VOX arrangement as would have been sensible. However, my friend now armed with the circuit managed to clip one end of a diode, I didn't catch which one, and it apparently works now exactly as he'd hoped using his sequencer and the PTT input.
Thanks once again for taking the time to reply. You've both been very helpful.
Denis
Old 17th Feb 2021, 11:54 am   #5
Terry_VK5TM
Cheers Denis, glad your friend finally has it working as he wants.
Terry VK5TM
