21st Jan 2021, 9:12 pm | #1 |
80M AM European net.
For those of you who are interested.... as well as the UK 3615KHz AM net there's a semi-regular European oldtimer AM net on 3600KHz featuring PA/PE/F/ON operators.
In the last few weeks I've had some nice early-evening chats with our near-European friends, using only 7.5W from my PRC320. [I have local S9++ QRM/QRN burbler-issues here on 3615, which is frustrating] |
22nd Jan 2021, 12:56 am | #2 |
Re: 80M AM European net.
That's interesting. Is the net in English? I assume so, as most Europeans speak it so well don't they.
I wonder if the French are still doing AM nets down on 3.550 ? 73 Aub
22nd Jan 2021, 7:25 am | #3 | |
I've found the KIWI SDR on http://ixworthsdr.hopto.org:8073/ is quite good for AM on 80 and 60 metres during the daytime. 73 Roger/G3VKM |
22nd Jan 2021, 2:33 pm | #4 | |
B
22nd Jan 2021, 5:54 pm | #5 |
My antenna is a 100-ish-foot-long end-fed; tuned using a big Redifon roller-coaster unit] on 80M, using an array of galvanised fence-spikes as ground. Works rather well!
The burblie on 3615 is annoying. It's not caused by anything in the house [I've powered the PRC320 from batteries and then turned off the incomer - the burbling continues unabated.] |
22nd Jan 2021, 6:03 pm | #6 | |
I thought maybe the net I joined was somehow associated with VERON [the Netherlands equivalent of the RSGB] but I can't find anything about it on their website. I don't speak any Dutch, alas - but I have schoolboy-French and my technical German is quite good! |
22nd Jan 2021, 7:11 pm | #7 |
I'm not a radio amateur myself, but I understand there used to be a regular 32-line NBTV net on 80 metres. So, listen out for that ancient televisual "rhythmic hum" sound.
Steve
https://www.radiocraft.co.uk |
22nd Jan 2021, 8:28 pm | #8 | ||
https://www.pi4srs.nl/wp/ Scroll down to select language. 73 Roger/G3VKM |
22nd Jan 2021, 8:30 pm | #9 | |
