Old 29th May 2019, 3:08 pm   #1
Steve G4WCS
Steve G4WCS's Avatar
Default Ten Tec 6-2M transverter
Managed to pick up this transverter. Built from a kit.
On the whole it seems well designed, uses a discrete mixer and pin diode switching.
It looks to have had a final transistor replaced and a couple of addintional leds cobbled On.
Plenty ferrites in there.
Need a suitably vintage prime mover now. Happy days
ID:	184129   Click image for larger version
ID:	184130   Click image for larger version
ID:	184131   Click image for larger version
Steve G4WCS is offline
Old 29th May 2019, 4:38 pm   #2
Jon_G4MDC
Jon_G4MDC's Avatar
Default Re: Ten Tec 6-2M transverter
If those PA transistors ever need replacing you will have a hard job Steve.
What has been out there for last 10 years are almost all 100% fakes.
Hope yours are good.
Jon_G4MDC is offline
Old 4th Jun 2019, 3:08 pm   #3
Steve G4WCS
Tested and working. Input attenuator resistors are set for 5 watts so its putting 6 watts out on 50 with 1 watt input from the IC-260
https://youtu.be/aUchWYqVcb4
https://youtu.be/ELzPJ0y_EBg
