Old 10th May 2019, 9:33 am   #1
ribbonmicsrus
ribbonmicsrus's Avatar
Default 1134A intercom amplifier
Restoring one of these for a friend, have found T2 secondary windings O/C. Has anyone with similar problem fitted an alternative transformer in this position.
I do not fancy rewinding it!
Andy G3UEQ
ribbonmicsrus is offline
Old 10th May 2019, 9:55 am   #2
pnh0001
Default Re: 1134A intercom amplifier
Hi Andy
I had the same problem with mine, one half of the secondary was o/c Initially I replaced with a 3:1 interstage transformer from Antique Electronic Supply. That worked fine.
I also rewound the entire transformer primary & secondary as I destroyed the primary some how in getting the secondary windings off. Rewinding was a real pain, I made up a winder in meccano that automatically went backwards and forwards to lay out the windings. Took hours, but again the end result worked fine and is indistinguishable now from original.
You can see my winder here:
https://www.youtube.com/watch?v=KWIVDToPSIE
At that point it was doing one half of the secondary winding, (the primary had been done) the bits of white are dowels holding the space of the second half of the secondary.
regards
Peter
pnh0001 is offline
Old 10th May 2019, 10:11 am   #3
HamishBoxer
HamishBoxer's Avatar
Andy,Ed Dinning on our group can rewind.
HamishBoxer is offline
Old 10th May 2019, 10:49 am   #4
ribbonmicsrus
Hamish
Had thought of that, I think he is a bit busy at present but will contact him
Andy
Originally Posted by pnh0001 View Post
Hi Andy
regards
Peter
Peter
Love the winder, brilliant, wish I had kept all my Meccano as a kid!
OK on replacement transformer, will look into that.
Peter, was the transformer from Antique their P-T156 3:1 interstage?
Andy
Old 10th May 2019, 11:21 am   #5
Keith
Keith's Avatar
I had a similar problem, mine having an o/c T1 secondary. They're quite easy to dismantle. I rewound mine with a hand drill (but I have to admit the Meccano winder made by Peter looks like a far better proposition - absolutely wonderful). http://www.tibblestone.com/oldradios...adio/T1154.htm
Interestingly, the original winding had spliced breaks in it. I guess materials were in short supply at the time!
Keith Yates - G3XGW
VMARS & BVWS member http://www.tibblestone.com/oldradios/Old_Radios.htm
Keith is offline
Old 12th May 2019, 2:30 am   #6
pnh0001
Andy
Yes that was the one from AES, fits in easily and works fine
Peter
pnh0001 is offline
Old 12th May 2019, 7:57 pm   #7
ribbonmicsrus
Thanks Peter
Appreciated.
Andy
Old 16th May 2019, 6:32 pm   #8
ribbonmicsrus
Andy
Peter
Peter
One has been ordered !
Andy
Old 1st Jun 2019, 4:38 pm   #9
ribbonmicsrus
Replacement T2 Antique Electronic Supply, fitted and works well. Using an old static noise cancellng microphone, getting about 4-8v p-p drive for T1154.
Andy G3UEQ
