Old 26th Jun 2010, 6:23 pm   #21
Default Re: Re-stuffing the waxies.
Originally Posted by Kat Manton View Post
A versatile appliance is the 1.5 kW hairdryer...
That's got more grunt than my Black and Decker
Herald1360 is offline
Old 11th Jun 2011, 8:09 pm   #22
HamishBoxer
HamishBoxer's Avatar
Of course the other way is,being leaky just let them warm up with HT on them and they come apart so easy!
It worked on a French restoration i did.
HamishBoxer is offline
Old 11th Jun 2011, 9:17 pm   #23
Yes. I guess it would. I might give it a go. The last one I touched was across the main HT and it was very/extremley hot as our kitchen table will bare testiment to.
Thanks for that David, also my appologies for my last reply on the same subject in the other section as I had your user name Hamish mixed up with your actual name.
Old 14th Jun 2011, 4:05 pm   #24
HamishBoxer
Its get confusing Lawrence,dont think twice about it.
Regards David
Old 14th Jun 2011, 4:06 pm   #25
HamishBoxer
PS it possibly wasnt the best way of doing the re stuffing,due to some extra stress on rectifier and mains transformer
Old 14th Jun 2011, 5:44 pm   #26
"He who hesitates is lost" I will sit down for a while while I decide on the best approach....seriously though I will use a sensible approach and all of your comments have been welcomed..I have to order some replacement caps etc yet, when I finally get the job done I will try and upload some pics.
Has anyone restuffed a smoothing cap (electrolytic) the type that fit to the chassis by a largish nut from underneath ( the two wires coming out through the nut /gland,
ala Hallicrafters sx etc ?
Old 17th Jan 2015, 5:21 pm   #27
cabover1
Hi John nice job with restuffing the caps. I don't think it will be a problem for future genarations with the restuffing of caps like some people think, after all what would we do if there was nothing to change in these old radios and stuff. I'm sure in another 40 years or so someone will want to poke in there and have fun and learn something about their equipment and have fun doing it.
Thanks for your time John and effort keep up the good work.
cabover1 is offline
Old 17th Jan 2015, 10:20 pm   #28
HamishBoxer
Re the electrolitic some have just sawed them in half and then cover up with either a made up label or just pvc tape.
Old 17th Jan 2015, 11:37 pm   #29
60 oldjohn
"Just sawed them in half" Neatest way to cut them if you have one available is a Pipe Cutter (the wheel type)
John.
60 oldjohn is offline
Old 18th Jan 2015, 10:46 am   #30
Stockden
I've used a strip of the "aluminium" adhesive tape sold by Lidl. It's much less obvious than PVC. (assuming that the cap has a plain metal case rather than a card/plastics covered one).
Hugh
Stockden is offline
Old 18th Jan 2015, 8:43 pm   #31
HamishBoxer
That sounds the way to go Hugh.Thank You from me for that.
PS I have not seen that tape but will keep an eye out.
Old 19th Jan 2015, 8:56 am   #32
Stockden
It's one of those things that Lidl do from time, usually in conjunction with masking tape, gaffer tape etc. Other vendors are available of course and Googling for aluminium tape (or aluminium foil tape) produces a good few results (e.g. here).
Hugh
Stockden is offline
