15th Sep 2012, 9:37 pm | #1 |
Cessna 300 nav/comm receiver
Does anyone have any info on this most interesting beastie - I know there are several variants - this one is full of compactrons and nuvistors.
I would like to know the connections for power and audio, as well as supply voltages..... Being as it came in amongst a mixed auction lot, I would be rather hesitant to spend 60+ USD on a manual.... Cheers Sean
19th Sep 2012, 7:55 pm | #2 |
Re: Cessna 300 nav/comm receiver
Hi Sean, can you post a picture as I don't think Cessna made nav/com sets, so it may be badge engineered. There is also a lot of standardisation of connections between the various manufacturers.
Ed |
20th Sep 2012, 11:26 am | #3 |
Cessna Radios of this vintage were made by A.R.C. (Aircraft Radio Corp.) They were very unreliable compared to their competitors' products made by King and Narco. Their connections were also different from any others. They were designed to fit into the instrument panel of light aircraft.
Some of them required an external power supply unit. You will need a hefty 12 volt supply to run it. Chris. |
20th Sep 2012, 6:14 pm | #4 |
Thanks Chris, having a nose around inside the unit, I can certainly see why they might be unreliable - I've seen tidier rats nests!
Time to Google! Sean
