29th May 2019, 5:56 pm | #1 |
Need a very low power 500Khz working transmitter to send morse code.
I have purchased a Marconi Atlanta Marine Radio.
I am purchasing a non-working Oceanspan Transmitter. I want to demonstrate it working. I need a very low power 500kHz transmitter that I can use alongside the receiver and I need the transmitter to also transmit on another frequency 512kHz to show, how we used to use 500kHz as a calling frequency. There output power can be in mWatts. |
29th May 2019, 9:46 pm | #2 |
Re: Need a very low power 500Khz working transmitter to send morse code.
Signal generator feeding a dummy load?
29th May 2019, 10:27 pm | #3 |
I promise I'm going to stop collecting radios when I've got an Atalanta 2207C
- Julian It's good here |
29th May 2019, 11:33 pm | #4 |
There's lots of ways to generate the signals, including a 74HC4060 and crystal(s).
However, as you will be running the transmitter right next to the receiver I would recommend running the signal source at twice the frequency (continuously) but key a flipflop divide by two (74HC74?) as the morse sender ahead of the final stage and LPF. That way, there will be 'nothing' heard in the receiver in the gaps between morse characters, i.e. no constant low level leakage tone if the transmitter is right next to the receiver. Otherwise, you would have to screen the low level stages of the transmitter very well in order to avoid a constant leakage tone appearing in the background in the receiver. The alternative is to key the oscillator on and off but that will probably sound a bit chirpy and unpleasant.
Regards, Jeremy G0HZU Last edited by G0HZU_JMR; 29th May 2019 at 11:38 pm. |
29th May 2019, 11:50 pm | #5 |
It really all depends on what you want to do, which isn't very clear at the moment.
30th May 2019, 12:13 am | #6 |
Yes, it's not that clear. I assumed it would be the receiver connected to a regular outdoor antenna and the transmitter sat alongside the receiver running into a dummy load. The risk there is that the radiated morse signal from the dummy load might not be that much greater than the leaked radiation from the unkeyed oscillator inside the transmitter.
Regards, Jeremy G0HZU |
30th May 2019, 8:04 am | #7 | |
HTH Roger |
30th May 2019, 9:21 am | #8 |
Jeremy's 4060 divider method provides the answer to on/off keying without spacer wave for free by using the reset line Pin 12.
An 8.0MHz crystal should produce 500kHz at the first output Q4, Pin7. Use an 8.192MHz crystal instead (also commonly available) for 512kHz output. Last edited by Jon_G4MDC; 30th May 2019 at 9:30 am. |
