Old 21st Oct 2020, 7:43 pm   #1
EF80TVVALVE
EF80TVVALVE's Avatar
Default Amplion Convette M2V
Hi all,
I have one of these in original condition, I'm going to restore but also modify it for a radio that requires 4 HT supplies, the highest being 150 volts, so I'll get rid of the QPP supply and use this as the 4th HT supply socket.
Before I begin can anybody recommend a suitable load resistance so I can replicate output voltages on the unit without needing to connect it to the set?
EF80TVVALVE is offline
Old 21st Oct 2020, 10:24 pm   #2
Herald1360
Herald1360's Avatar
Default Re: Amplion Convette M2V
Difficult without knowing what load currents are taken at the various HT voltages.....
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 22nd Oct 2020, 12:52 am   #3
Herald1360
Herald1360's Avatar
https://www.vintage-radio.net/forum/...ad.php?t=14340
Has helpful circuit for the unit. Raw HT DC could be as high as about 190V but will be quite load dependent. Replacing the half wave rectifier with a small silicon bridge will give less ripple but probably even higher raw HT.
....__________
Old 22nd Oct 2020, 10:06 am   #4
EF80TVVALVE
Thanks for the link, researching a bit last night it seems a typical current draw is around 12mA although I'm not sure with a set that requires 4 HT supplies, that figure could possibly be for 50s attaché portables which I'd imagine would draw much less
I've replaced the HT rectifier with an 1N4007 and the unloaded (smoothed) voltage is 185v.
Old 22nd Oct 2020, 10:52 am   #5
Herald1360
Herald1360's Avatar
12mA does sound typical for a '50s attache case set and at just one HT- 90V.
If you know the valves in your set and which ones are on each HT voltage a reasonable stab could be made at load resistor values to enable you to "tune" the Amplion circuit to suit.
In any case, as long as you don't exceed the maximum Va ratings for the valves, you could just use the set as the load, it's unlikely you'll do any damage
....__________
Old 22nd Oct 2020, 12:44 pm   #6
EF80TVVALVE
I'm sure the valves are PM22, PM12 and PM1HF. Just guessing but HT4 is 150v which I presume is the Anode of PM22 and HT3 is 120v which I would think is the screen grid of the PM22. The other voltages are HT2 60-80v and HT1 60-80v, I imagine these are supplying the PM12 and PM1HF.
Probably worth me checking this properly but from the valves fitted and the voltages given I'd presume this is so.
I've been thinking it may just be best to run it up on a variac and make sure it doesn't overload the set, but practically it's probably easier to have some suitable loads on it to mimic working conditions whilst I modify it.
