21st Oct 2020, 4:16 pm | #1 |
More what are these components?
"A" is solid and measures 140mm x 20mm x 5mm a narrow copper trace runs full length under the two separate windings. Sadly one windings has a slight scratch and is OC. ?
"B" All test OC. ? "C1" & "C2" same item, different view ? "D" ? John.
My favourite text message "I'll be there in five minutes, if not read again" |
21st Oct 2020, 4:21 pm | #2 |
Re: More what are these components?
A could be a delay line?
B two VDRs and a spark gap. C miniature pot? D Thermistors. |
21st Oct 2020, 4:22 pm | #3 |
The bottom one of 'B' is a spark gap, probably gas-filled. It would be used to short out over-voltages on, say, a telephone line.
21st Oct 2020, 4:30 pm | #4 |
The parts in 'D' look like thermistors - they're quite sought after these days. Types RA52 and RA53 ring a bell.
Chris
21st Oct 2020, 4:32 pm | #5 |
I thought bottom of B may be a spark gap it was in a bag with the other two in the picture which also measure open circuit.
John.
21st Oct 2020, 5:26 pm | #6 |
A looks like an AVO resistor.
21st Oct 2020, 5:34 pm | #7 |
I think C1 & C2 are either a ceramic or possibly crystal resonator. Basing this on the SFR part number. Picture A does appear to be a twin resistor of high accuracy, from some sort of test equipment.
Dave |
21st Oct 2020, 6:05 pm | #8 |
Photo 5 second from left (leads upwards) looks like a reed switch
Derek |
21st Oct 2020, 8:07 pm | #9 |
One of the 'things' in the rightmost photo looks like a form of mercury-wetted switch; the oddly-shaped bracket would suggest that it was intended to be mounted to something which was then tilted to open/close the contacts.
I remember seeing something similar used to activate a bell on the door of a shop back in the 60s. |
22nd Oct 2020, 4:15 pm | #10 | |
If picture B are VDR's are they useless ? they measure open circuit at room temperature. John.
22nd Oct 2020, 4:59 pm | #11 |
They do at low voltages. They will be OK.
