Old 25th Oct 2020, 8:40 am   #21
Neutrino
Neutrino's Avatar
Default Re: Metal Rectifier in Pam TR 26
Originally Posted by Dick Glennon View Post
One other point as well, the set only has three valves ,UBC 81 (14volts) UBF 89 (19volts) and UCL 83 (40volts). R16 has gone open circuit. What wattage would I need to replace it and what voltage should I have where R 16 meets V1.
UBC81 is a double diode triode which does not appear correct because a superhet needs a frequency converter. The valve line-up can be confirmed with the Vintage Radio Service Data available from the link at the top right of this page. With UCH81, UBF89 & UCL83 the heaters add up to 78 V which is the approximate voltage that you should have where R16 meets V1.
Neutrino is online now
