Old 10th Sep 2022, 1:09 pm   #1
Workshopboy
Default Hitachi SP2900 8 Track
Hi all
Can anyone help with the type of bulb In this unit. The bulbs are wired to the end of the supply cable in the radio display and both VU meters. They are all blown and require replacement. The unit also requires belts and motor mount replacement. But the bulbs I can't seem to find online, so looking for something I can purchase easily and solder in as a replacement.
Many thanks
Workshopboy is offline
Old 10th Sep 2022, 2:11 pm   #2
G6ONEDave
G6ONEDave's Avatar
Default Re: Hitachi SP2900 8 Track
Looking at the service manual all the bulbs are probably 12v operation, I would suggest a current rating of 50/60mA. There are no specifications given re the bulbs but you could use the small pea bulbs that have short wires attached, if you can track some down. Otherwise use some white LED's but remember the series resistors if the LED's are not rated at 12v.
Dave
Quote "All is hyperthetical, until it isn't!" (President Laura Roslin, Battlestar Galactica)
G6ONEDave is offline
Old 10th Sep 2022, 2:27 pm   #3
G6ONEDave
G6ONEDave's Avatar
Sometimes these bulbs are called rice grain bulbs.
Old 10th Sep 2022, 2:44 pm   #4
Workshopboy
Thanks all I will take a.look
Old 10th Sep 2022, 4:18 pm   #5
Cobaltblue
Cobaltblue's Avatar
I have always known them as Grain of Wheat lamps some examples here:
https://www.ebay.co.uk/sch/i.html?_f...c&LH_PrefLoc=1
The Scaletrix ones look promising.
Mind you as they are probably all made in China now Rice is just as likely
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is online now
Old 10th Sep 2022, 5:16 pm   #6
Workshopboy
Ordered a pack of 10 today. Will let you know how it goes
Old 10th Sep 2022, 7:09 pm   #7
emeritus
Also used for dolls house lights, although I suspect LEDs may have taken over. The last grain of wheat wire-ended bulbs I got as dolls house accessories a few years ago were nominally 12V, but had short lives on 12V and soon went black, so I derated them to 9V.
emeritus is offline
