5th Sep 2022, 11:58 pm | #1 |
Fidelity Playmaster Major 4
There is one of these tape recorders for sale near me very cheap but in need of repair. Is this a transistorised model? I have never seen one before. It looks impressive but are they any good? I seem to recall that the Fidelity transistorised ones got bad technical reviews. The deck looks like a BSR TD10 so not all bad. I love fixing old tape recorders and for a tenner might take a chance. Has anyone got one in their collection?
Regards Martin |
6th Sep 2022, 9:40 am | #2 |
Re: Fidelity Playmaster Major 4
Hi
The Playmaster Major was reviewed by Alec Tutchings in Tape Recorder, and H Burrell-Hadden in Tape Recording Magazine. It received excellent reviews by both reviewers. It had correct CCIR equalisation on each speed, very good frequency responses at all speeds, and was described as having a decent sound quality from its large internal speaker. Overall, Alec Tutchings said it was an excellent design. So, it begs the question, what happened when Fidelity produced the transistorised Playmaster? |
6th Sep 2022, 9:42 am | #3 |
Martin I have no experience with any of the many Fidelity models.
Looking at the service sheets for the Fidelity Playmaster Major I see there is a 2 track and a 4 track model so I assume the Playmaster Major 4 is the 4 track. The service sheet shows it is a valve machine with a single transistor so technically it could be called "hybrid". David |
6th Sep 2022, 9:49 am | #4 |
Their designer evidently knew what he was doing with valves, but not transistors. Or maybe cost constraints prevented the use of enough transistors to give the necessary gain for proper equalisation. After the debacle of the transistorised Playmaster, Fidelity reverted to valves with the odd transistor here and there.
6th Sep 2022, 9:49 am | #5 |
I think David in post 3 is maybe referring to the Playmaster in this linked Thread, I do not know for sure but do not think it was the "Major" model.
https://www.google.com/url?client=in...Z7FD4P7hVCiI1S David |
6th Sep 2022, 9:50 am | #6 |
The Playmaster Major was only ever produced as a 4 track model. It isn’t strictly a transistor recorder. The single transistor was used as a low noise head amplifier in the playback circuit.
The valve lineup is EF86, ECC83, EL84, ECL86. The single transistor is an AC107. |
6th Sep 2022, 10:06 am | #7 |
Well, for a tenner I'd go for it! As I'm sure you know, the TD10 is easy to service and the electronics shouldn't be too taxing. I like the VU meter as opposed to the more usual magic eye and the EL84 output stage should be plenty loud enough.
Go on - it'll soon be time for winter projects. |
6th Sep 2022, 10:08 am | #8 |
Yes now after rechecking the service sheets can see it is only 4 Track, I think I must have been incorrectly looking at the Playmaster 2 while checking out various service sheets.
David |
7th Sep 2022, 2:14 pm | #9 |
Thank you all for your replies, I didn't know it was a valve model. Unfortunately when I made enquiries, someone had beaten me to it. The seller had forgotten to cancel the advert. If another one comes up (unlikely), I will grab it straight away. Nice that this model received good technical reviews, Fidelity products have usually been bargain basement.
Regards Martin |
7th Sep 2022, 6:51 pm | #10 |
The TD10 was more versatile than the TD2, but still suffered from noisy idler and slow winding speed. I think the heads were not particularly good either and prone to wear.
Fine for the price but there are far better machines out there IMO.
Regards, Ben. |
