Old 4th Oct 2022, 10:19 am   #1
stephen_g
Default Hickok type 81 fuse lamp.
Hello all,
Does anyone have any of the type 81 fuse lamps as used in the Hickok 539A valve tester please, or know of a supplier in the UK?
It is a single contact bayonet lamp BA15S base, GE part number is GE-25736-81.
Thanks
Stephen
stephen_g is offline   Reply With Quote
Old 5th Oct 2022, 7:50 am   #2
Kevin Hoyland
Default Re: Hickok type 81 fuse lamp.
Morning Stephen.
The bulb that you are after is a car / truck bulb and that's all . But for years people in the USA say that if you do not use the right one the tester plays up. I am sure Lucas made one in the UK that is the same.
Kev.
Kevin Hoyland is offline   Reply With Quote
Old 5th Oct 2022, 9:06 am   #3
stephen_g
Morning Kev,
Thanks for your post, I'll keep searching!
Kind regards
Stephen
Old 6th Oct 2022, 1:26 pm   #4
brunel
brunel's Avatar
36 pages of BA15S lamps here.
https://www.cp-lighting.co.uk/Lamps?search=BA15S+
brunel is offline   Reply With Quote
Old 6th Oct 2022, 3:35 pm   #5
broadgage
The correct rating is important. Various sources give this as being 7 watts at either 6.5 volts or 7 volts.
Probably used as marker lights/side lights in USA. A more common rating in the UK is 5 watts.
broadgage is offline   Reply With Quote
Old 7th Oct 2022, 4:41 pm   #6
usradcoll1
The #81 lamp was used in US c*rs pre 1956 as back-up and interior lighting and readily available in auto parts stores and garages. The lamps, at the time were rated 6-8 volts. It probably would be best to source US made lamps!
BTW, the fuse lamp glows rather brightly when testing high current rectifier valves, such as a 5U4 at inrush and glows slightly when valve is heated.
Dave, USradcoll1
usradcoll1 is offline   Reply With Quote
Old 8th Oct 2022, 3:54 am   #7
FrankB
Be sure the bulb height is the same as the one you are replacing.
I had one that was too high and would not fit properly.
If you can find an older U.S. made bulb it should work OK.
I bought a master box of 12 at the auto parts store for less than the price of a 2 pack on the peg board. But the glass was a bit too tall. Chinese import bulb. Also have heard of others where the bulb will not work properly due to current/ voltage differences in the import bulbs.
If I had a spare, I'd send you one, but I need a couple for my own T/T for spares. Hard to find even here.
FrankB is offline   Reply With Quote
Old 8th Oct 2022, 7:25 am   #8
vidjoman
My list of US numbers from GE shows #81 as - #81 Bayonet Base 6.5 volts @ 1.02 amp
vidjoman is online now   Reply With Quote
