5th May 2022, 2:58 pm | #1 |
German control unit from WW2?
I have purchased a control unit with the following details on
Bedg-FBG4 Anforder Z Ln26688 Herst.bou The two pots on the front and two switches are in german on its rear is a 10/10 in line connector to be attached to a radio? Does any one know what this was for? 73s Andy 2E0NDZ |
5th May 2022, 3:08 pm | #2 |
Re: German control unit from WW2?
Anforder = requestor.
Herst. is abbreviated Hersteller = manufacturer. What's the German on the controls, please? |
5th May 2022, 3:48 pm | #3 |
This has the same LN number/FBG number:
https://milcollectibles.com/index.ph...product_id=534 Which is item 33 in here, remote tuning (fine) of something apparently, receiver?: https://www.deutscheluftwaffe.de/coc...ofil-ju-87-d-5 Lawrence. Last edited by ms660; 5th May 2022 at 4:14 pm. Reason: extra info |
5th May 2022, 4:05 pm | #4 |
Interesting, so its a Fernbediengerät which = remote control apparatus.
There appears to be an on/off switch for a headset. |
5th May 2022, 4:39 pm | #5 |
Sensitivity (left)
Fine tune (right) According to Google Translate. Lawrence. |
5th May 2022, 7:27 pm | #6 |
Squelch control? If indeed it IS exclusive to the Ju87-(which isn't clear) it's likely to be scarce.
Dave |
5th May 2022, 11:22 pm | #7 |
Thank you for the help
on the front it has the words empfndichket above a pot and fenatsi above the second pot and horet above the 4 way switch A nice find very 73s Andy |
6th May 2022, 8:10 am | #8 |
Any chance of a picture?
6th May 2022, 8:22 am | #9 |
The first control (pot) has Empndichket above it
the middle switch has Ein and Aius at side of switch the other control (pot) has one side Aus and other Fenatsi The photo is as sent by a reader above 73s Andy |
6th May 2022, 2:45 pm | #10 | |
Hugh |
8th May 2022, 3:57 am | #11 |
Hello Hugh
Thank you, Do you know what equipment this was attached too, or the contact details of a Museum in Germany? 73s Andy |
8th May 2022, 10:19 am | #12 |
So far as I can make out the radio kit in the JU87 was the FUG16Z (R/T) and the FUG25A (IFF)
Lawrence. |
8th May 2022, 1:53 pm | #13 |
From a couple of poor res. images of Ju87 cockpits i can make out a unit that looks quite similar to the one Andy has. The one example of this a/c that we have in the UK is probably still at Hendon, but a) it was modified to a newer spec. whilst in service and b) the brief flight trials undertaken by the British wouldn't necessarily have required a functioning radio. (So a visit may be disappointing even if you could get near it.)
Dave |
8th May 2022, 6:21 pm | #14 | |
Having done a bit of googling I'd agree with Lawrence that the most likely candidate is FuG16, though I can't find any pictures of that radio which your control box (or anything like it). Early models of the JU87 seem to have been fitted with a different radio, which presumably explains why some JU87 cockpit pictures show the control box and some don't. As to potential museum contacts it may be worth trying the Bundeswehr Museum of Military History (scroll well down the page to find an email address) and/or the Bundeswehr's Luftwaffe Museum at Gatow. Finally, if you can find contact details for the person behind this video they may be able to help. Good luck! Hugh |
8th May 2022, 6:27 pm | #15 |
I think that R/T might have been behind the pilot in the area that the operator/rear gunner was, apparently some JU87's were fitted with that R/T and some were not, possibly the earlier ones.
Lawrence. |
