30th Apr 2022, 10:27 am | #1 |
Dansette HiFi Mk2 smoking amplifier
I recently aquired a Dansette HiFi Mk2 from 1964 via an auction. After unpacking I switched it on and got a continuous buzzing noise and little else (a bit of a smell though and some crackling), so I immediately turned it off and thought it was the usual suspects. I've restored about a dozen Dansettes including a HiFi, so I replaced all of the capacitors including the huge 50+50 can. Switched it on again and the same buzzing. This time I noticed a bit of smoke as the amp warmed up! Switched off and headed for those that know a lot more than me. From a previous thread (https://vintage-radio.net/forum/showthread.php?t=95222) I'm assuming that it could be a faulty transformer or rectifier (where is the rectifier on this model?). The poster (Caled2013) resolved the issue by replacing the transformer, but there is no indication as to what the spec might be. I have a schematic, but that doesn't say either. This version of the amp has two ECL86 valves (one is the original Mullard, the other is an unbranded 'foreign' made replacement). Any suggestions would be very welcome as I'd love to get this going again. Picture of the amp is attached. Thanks.
30th Apr 2022, 10:29 am | #2 |
Re: Dansette HiFi Mk2 smoking amplifier
The valve on the left seems to have lost its getter, therefore its vacuum unless the getter is somewhere else on that valve
Cheers Mike T
30th Apr 2022, 10:32 am | #3 |
I believe the valve which has lost it's getter is the rectifier an EZ81 probably
Graham |
30th Apr 2022, 10:38 am | #4 |
Both valves are ECL86. The one on the left is original Mullard and the one on the right is an unbranded foreign make.
30th Apr 2022, 10:40 am | #5 |
Excuse my ignorance, but what do you mean by 'lost it's getter'?
Mike |
30th Apr 2022, 10:43 am | #6 |
There is no EZ81 in this. The amplifier uses a bridge-rectifier which I think may have failed. It may need replacing with a 4 diode configuration.,
Edward. |
30th Apr 2022, 11:09 am | #7 |
According to a very video on YT, it does indeed use a 4 diode bridging rectifier. Would it be that Westinghouse EC20 unit on the left of the image?
_____________________ Mike H |
30th Apr 2022, 11:10 am | #8 |
Forgot the image!
30th Apr 2022, 11:14 am | #9 |
The valve on the left has definitely lost its vacuum.
I've been working on a slightly different version of this amplifier recently and had to replace the rectifier for the second time. Unfortunately in failing it took out the mains transformer. https://www.vintage-radio.net/forum/...d.php?t=128996 Post 35 onwards.
30th Apr 2022, 11:17 am | #10 | |
If its like the one on the left of the picture. The mirror shiny bit is the getter it mops up residual gas. If its milky white then the valve is useless. Not all valves have a visible getter though.
30th Apr 2022, 11:19 am | #11 |
30th Apr 2022, 11:39 am | #12 |
Ok, thanks guys. One of the valves has definately had it then and probably the rectifier. They next question is - how do I replace that rectifier?
30th Apr 2022, 11:44 am | #13 |
I suggest that you test the rectifier to make sure it's actually faulty before replacing it.
You could replace it with four diodes on a tag strip or with a bridge rectifier as shown in the attached picture.
30th Apr 2022, 1:07 pm | #14 |
Ok, I'll test first. Thanks for the image and advice.
30th Apr 2022, 1:12 pm | #15 |
The Mk1 version of the Dansette Hi Fi has a more visually substantial drop-thru mains TX. But that in the Mk2 version appears to be able to well handle the increased power demands of the ECL86s.
Edward. |
30th Apr 2022, 1:33 pm | #16 |
The valve which has lost its vacuum won't have been emitting smoke itself, so there will be some damage elsewhere. Transformers can be got smoking hot. IF you're lucky you may have caught it before permanent damage was done. Solid state rectifiers like that bridge can also go up in smoke. In this sort of fault finding, you have to look not only for the cause, but also any victims damaged as a result.
Those valves are not cheap, but not terribly expensive, they are available. The transformers are more serious if damaged, but there are people who can re-wind them. All the other components are somewhat easier to source. So it can be repaired, if it's thought worth the cost. David
30th Apr 2022, 2:14 pm | #17 |
You soon know if a metal rectifier goes by that acrid smell! Yes, transformers can be replaced, but a Push-Pull, Ultra-Linear OPTX can be surprisingly expensive. One wound for EL84s should be a very good match - unless Ed Dinning advises otherwise!
Edward. |
30th Apr 2022, 9:39 pm | #18 |
I stand corrected.
Graham |
18th May 2022, 2:54 pm | #19 |
Well, I've replaced the old Westinghouse rectifier with a modern Bridge rectifier as suggested and switched on to see what happens. It now has a quieter buzz which, after a while, is getting slightly louder as it warmed up. A HiFi Mk2 should be much quieter than this.
Could it have been the transformer after all?
18th May 2022, 3:18 pm | #20 |
It is my eyes or are there dry solder joints on the main reservoir / smoothing electrolytic? That could cause hum.
It is probably time to start taking voltage readings for diagnosis. HT feed (AC and DC) & pentode electrodes would be informative. |
