23rd Aug 2021, 10:31 am | #2481 |
Re: Brand new hifi record players with built-in speakers
23rd Aug 2021, 11:45 am | #2482 |
Done.
23rd Aug 2021, 6:56 pm | #2483 | |
And they are retail prices. Negotiate and commit to volume and you can divide those numbers by two, or even three. In fairness that is a well thought of basic deck combo, and has been going in various guises since Adam was a nipper. Craig |
28th Aug 2021, 11:22 am | #2484 | |
Terry |
28th Aug 2021, 11:58 am | #2485 |
Re: The Audiophoolery Thread.
Hello,
To keep a balance... Forgot to add... Rega does a complete system comprising of P1 Deck, amplifier and Speakers for around £1000 all made in the UK and Sunny Southend in Essex! Terry |
28th Aug 2021, 12:30 pm | #2486 |
So where did the Acos Rega turntable fit in?
28th Aug 2021, 2:09 pm | #2487 |
I have just got three Toslink "cables" for a quid or so each, they work well. While looking for them I came across this https://www.directnine.uk/products/5...nhattan-317924 at £9,044.40 each (40% off too), at least one doesn't need two for stereo!
28th Aug 2021, 3:34 pm | #2488 |
I thought I'd heard everything in this long and winding thread. But over £9k for a Toslink optical cable is ridiculous turned up to 11.
Craig |
28th Aug 2021, 4:02 pm | #2489 |
The Acos turntable came pretty much at the beginning of the life of Rega ahead of the Rega Planet and Px turntables, from memory it was a marketing collaboration between Cosmocord and Rega to make and sell turntables under the Rega Acos name. The early turntables used the Acos Lustre arm and that was also part of the deal. This didn’t last for long though, and the Acos collaboration was disbanded.
Terry. |
28th Aug 2021, 4:26 pm | #2490 |
Ah, I had an Acos Rega with lustre arm for many years. My brother still has it. It was fully satisfactory.
Toslink £9k ! MM, you should now be regretting getting a cheaper one. If you had one of the £9k jobs, just think of the data coming out of the optical modules... the scintillating pinpoint 1's, the deep, velvety 0's. And as for the reassembled music, the adjectives you would have to deploy would strain anyone's vocabulary. David
28th Aug 2021, 5:14 pm | #2491 |
The universal version of the Lustre had a couple of weak points - the lock for the height adjust could crack the plastic lower moulding if overtightened (don't ask me how I know) and of course the toothed bias belts are starting to fail now after 40+ years. Not a bad old tool, though.
28th Aug 2021, 5:48 pm | #2492 | |
One day I may get a HiFi, meanwhile I just listen. |
29th Aug 2021, 9:28 am | #2493 | |
Absolutely nothing you can do with the bit of optical string that connects a TOSlink transmitter and receiver will compensate for the shortcomings of those modules. And that is before you factor in that the LED in the transmitter has a finite life, with the optical power reducing over time. Of course most audio nuts leave their gear on all the time, practically guaranteeing that the whole link will be below par. The whole rationale between this optical link was back in the days of red-book 16bit 44.1kHz audio. The joke used to be that TOSlink meant that you TOSSed the cable in the waste bin, or that only Tossers would use one. Having said that, I use TOSlink cables (cheapo ones) from each TV - but largely because that is practically the only way of getting an audio output from the things now. The only real advantage is electrical isolation of this link. You can do a whole lot better with coax with pulse transformers at send and receive to give galvanic isolation. Of course the devil is in the detail, because so called audio pulse transformers do not like working at 75 ohm send and receive impedances. But you can match them very nicely using resistive pads. It is pretty straightforward to get clean rise and fall of ~3.5ns. Whether optical or coax in this context uses SPDIF (Sony Philips Digital Interface Format) signaling, which is in itself a historical peculiarity from the early days of red-book CD in the early/mid '80s. Craig |
29th Aug 2021, 11:50 am | #2494 |
Good to read a veteran Rega still doing sterling service. I recently helped Greg (BVWS) get a skip find early Rega up and going again and back to rude health.
I feel another reason for optical connections being popular is the optical transmitter is disregarded when it comes to EMC compliance testing whereas the Co-Axial, being a (wire) cable connection, will be more likely to radiate RFI thus making EMC compliance a little trickier. The best optical transmitters and receivers are the Toshiba parts, the clones work OK, but the Toshiba are far better. I think my optical connectors came from Farnell or CPC. Terry |
29th Aug 2021, 12:08 pm | #2495 | |||
*I made a scart to audio cable last night for my set top box radio feed to the "HiFi", the bit of "interconnnect" had a simple two core, non screened, inside. I feared not and it works (no audible hum). Sorry folks, veering into the engineering... |
29th Aug 2021, 12:30 pm | #2496 | ||||
Of course this is all down to the standardisation of something from the early days of CD. Given a free hand now you would not come up with TOS. You'd use something with a decent bandwidth - there are lots to chose from right up to Terabits per second (not that there is any need for state of the art fiber backbone standards!). But you take my point. Then you could do away with a PLL by separating data and clock, and just synchronise data either at the send or receive end. Job done. But we've ended up with TOS, and rip off merchants selling foo optical bits of string for nine grand to people who have deep pockets and know no better. Craig |
29th Aug 2021, 1:04 pm | #2497 |
A lot depends on where the data came from. Some sources can be quite jittery, so as well as fixing corrupted bits from CRCs, you probably do want to re-sync to a good low-jitter clock.
This brings up the issue of the clocks being slightly different and eventually you wind up with either a sample too many, or a sample too few. In the old Plesiochronous world, you had padding bits you could grow or sacrifice, but you still wanted a regular flow of samples to your DAC. The subsequent SDH world relies on everything being synchronised and no need for padding. I suppose the whole thing goes belly up if there is a GPS failure. So with a need for regular feeding of the DAC, you need a clean clock oscillator, and you need a 2-port buffer. You can either manage the buffer by using a PLL to adjust the outgoing sample rate to prevent overflows and underflows, or else you make the buffer the size of a complete CD, read the whole lot in before starting playing. Hey, if the mechanism has stopped before the music starts, that's a wooden stake straight through the heart of all those audiophile arguments for separate decks and DACs or separate power supplies. Also if the file read is verified as properly corrected and error free (with any re-reads needed done), that's another sacred cow on the cattle truck. Data is, well, just data. Do you think we could sell them special, extra thick USB and CAT5 cables for their internet browsing, claiming that the concepts they read will be more favourable to their beliefs? David
29th Aug 2021, 1:19 pm | #2498 | |
29th Aug 2021, 2:41 pm | #2499 |
A creative alternative designed by an old friend (Steve Sells, chief engineer at Naim) is to use a FIFO. The data is clocked in using the recovered clock from a PLL. The data is clocked out using one of several closely spaced high stability oscillators, selected on the fly to maintain the data pointer to register half full.
It turns out that it matters not a jot that the precise rate at which the data is clocked out (and into the DAC), or that this has frequency discontinuities every now and again, provided the precision clocks always have low phase noise. Craig |
30th Aug 2021, 1:34 am | #2500 |
There are modern high sample rate DAC's that use a sample rate convertor in front of the DAC so that it can be fed from a low jitter clock no matter how unstable the incoming data is.
