Old 22nd Jan 2021, 5:34 pm   #21
P-Sussex
Default Re: Sony SL-C7 Rebuild: Alive for 20 Seconds Then ‘POP” & Smoke
Thank you again everyone for the help
P-Sussex is offline
Old 22nd Jan 2021, 7:40 pm   #22
HurtyAC
HurtyAC's Avatar
Hi All. You have to be careful repairing these. Please note that some of these now elderly machines I have repaired, the large 4.7uf capacitors are special high current handling types, this is why they are so large for their value and you may find they are down in value which makes them useless. Look for green corrosion around their legs, if found you will need to replace along with the others mentioned. If you don't want to be lumbered with fixing switch mode power supplies the SL-C5 uses a linear power supply which is extremely reliable and much easier to fix if you have trouble.
HurtyAC is offline
Old 29th Jan 2021, 4:14 pm   #23
P-Sussex
Once again a big thank you. I got there in the end, redoing all my E.Cap replacement work with high quality caps which were much more expensive and from a very well known Catalogue/Dealer. The specs for the caps stated that they were suited for psu use. So the machine is alive, subject to a number of mechanical issues which I am working on.
P-Sussex is offline
