14th Mar 2010, 12:18 am | #1 |
Red coloured getter in CRT
Hello there,
Whilst having a look at my latest aqusition, a GEC BT1091 I noticed that the getter is rather red in colour and slightly transparent. I have not seen a getter that colour before. I presume as it is not silver in colour then it is likely suffering from gas. What make is the CRT and what would be a sittable replacement type. Many thanks, Christopher Capener
14th Mar 2010, 3:51 pm | #2 |
Re: Red coloured getter in CRT
Hi Chris,
Your CRT may not be faulty. If the getter used was a barium compound, it will leave a red deposit of the glass wall of the tube. Al. / Skywave. |
14th Mar 2010, 7:48 pm | #3 |
Two types of CRT were used in the BT1091. The most common type is a GEC 6504 with a strange 'pip' type EHT connector. A few Mullards were also fitted. As Skywave has said the getter need not be a hard 'mirror' and still give very good results. The 6504 is a 9" 'flat faced' triode and requires a higher focusing field than the Mullard tetrodes. Any 9" tube will fit providing you are willing to do a few mods such as maybe changing the base, fitting an ion trap, and arranging a mechanical fit. The 6504 has a 6.3v heater. The EHT potential is not critical and is given as 6.5kv in the GEC manual for the BT1091. Hope this helps? have you got as far as a picture yet? Regards, John.
14th Mar 2010, 10:28 pm | #4 |
These tube do go down to air sadly and i have at least four tubes that have suffered from this. but still worth trying it as you may be lucky. I bought a bt1091 at harpenden its getter is still silver so i have fingers crossed for this one. ferranti tubes work well as a replacement. but as stated above most 9" tubes can be used with simple mods. good luck. Danny
15th Mar 2010, 9:53 am | #5 |
Another problem with these GEC tubes is an intermittent or permanant O/C cathode connection within the tube. A sharp tap on the neck usually brings the picture back for a short period. It's a pity because these tubes are capable of giving a superb picture, very bright and contrasty, if you can find one....J.
