Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Repair and Restoration Services Wanted
Repair and Restoration Services Wanted If you need someone to repair or restore equipment for you please post your request here.
Old 5th Aug 2020, 8:58 pm   #1
Avinunca
Default Valve testing needed Shropshire
I am keen to test four 300b valves, two of which were installed in my SET audio amplifier when it popped a fuse. Not sure which ones were in it. It was a while ago.
I would like to establish if it was one of these which was responsible and wondered if there was anybody within reasonable distance of Shrewsbury who could run a quick valve test for me at reasonable cost. They are quite pricey so I would like to be sure the person with the tester knows his stuff!
Avinunca is offline
Old 7th Aug 2020, 1:19 pm   #2
Longespee
Default Re: Valve testing needed Shropshire
I have an AVO Mk2 machine, I'm not sure it's the best version for testing 300b's, but I'm just West of Leominster and I have tested my 300b' on it and a fee is not required.
Perhaps some may know the actual full 9 digit code for this valve and any points to take note of.
Regards
Sean.
All the best things in life have been carcinogenic.
Longespee is offline
Old 9th Aug 2020, 8:03 pm   #3
Avinunca
Regards
Sean.
Thanks to Sean's kind help valves are fully tested, so this thread can be closed.
Avinunca is offline
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright ©2002 - 2020, Paul Stenning.
