18th Jul 2023, 11:22 pm | #181 |
Re: Commodore PET 4032/8050/3022
Nice job changing and checking UE3, onwards to UE1:
Check the +5V supply is present across UE1's supply pins (+Ve = 14, GND = 7) Report the static states or waveform frequencies present on: Code:
UE1 pin 1 UE1 pin 3 UE1 pin 5 UE1 pin 13 UE1 pin 11 UE1 pin 9 Elsewhere, go to UD5, check the voltage on its supply pins (+Ve = 14, GND = 7) and scope these pins:- Code:
UD5 pin 11 UD5 pin 8 Last edited by SiriusHardware; 18th Jul 2023 at 11:28 pm. |
19th Jul 2023, 1:00 am | #182 | |
Bear in mind that 74LS TTL 'High' level only needs to be just over 2V at the input and spec for outputs can be as low as 3.5V (Although the NMOS 6502 should be a bit-higher on its outputs, but not quite very-close to the supply-rails like CMOS often is). Logic 'Low' tends to be somewhat closer to ground, with 74LS TTL (and NMOS?) outputs able to 'sink' much better than it can source current - Which they need to, as less 'noise-margin' for this, and so must be < 0.8V when low. At higher-frequencies, the 'scope may also be giving some misleading levels - especially at 16MHz, where loss of odd-harmonics due to sampling-frequency / analogue bandwidth limits, may result in a more -sine-wave' looking reduced-amplitude waveform being observed. 'scope probe ground connection is also more important at higher frequencies, So whilst you may get a good looking waveform on 1kHz cal output (Connecting a x10 ground lead as well is often necessary, for probe compensation / attenuator to function correctly), probing a much higher-frequency circuit can give ringing on high-levels / 'ground-bounce' on low-levels, if ground connection isn't kept fairly-short. |
19th Jul 2023, 1:06 am | #183 | |
Whilst these don't have internal timers that the more-sophisticated 6522 'VIA' has (and so a Beeb computer must have system one present), I'm wondering if the ports on it are needed to control internal things and not just external ports? - I presume your other now-working PET has one you can borrow (assuming it got socketed in that one, along with the many other IC's that got this done). |
19th Jul 2023, 8:16 am | #184 |
The 6520 in question is dedicated to the IEEE port and as such is not essential for the working of the machine but its absence could put the machine into a state where it is expecting 'something' from the 6520. It would be better to have one fitted than not fitted during the occasional optimistic switch-on.
With already two completely unrelated dead ICs in different parts of the machine, I am afraid this one may turn into another uphill slog like Colin's first PET with its inexplicable dead chip count. |
19th Jul 2023, 8:41 am | #185 | ||
I suspect my error in using the wrong time/div settings as per post #170 wasn't helping me with my readings.
I have the probes set to x 10 so I think I'm good there. Colin. Quote:
19th Jul 2023, 8:43 am | #186 | ||
I have a 6520 in from my other PET (they were socketed in that one) and 74164N donor chip in UE3 (replacements on order).
The only thing I don't regularly connect is the keyboard (I do every now and then just to see if it makes a difference). Colin. Quote:
19th Jul 2023, 8:44 am | #187 | |
More rust, less moss in this one. Let's see if it makes a difference.
Colin. Quote:
19th Jul 2023, 8:46 am | #188 |
For the most part, luckily, all we need to know is whether a signal is present or absent and whether it is the right frequency. I'm not too worried if we can't get a pretty looking picture of the 16MHz master clock as long as it is reaching the divider chain and the correct (divided) frequencies are coming out of the dividers.
The main problem we have encountered so far is a conflict between the frequency of the signal of interest and the sampling rate of the scope which at certain time / div settings has been too low, and we are aware of that now so hopefully we can work around it. |
19th Jul 2023, 8:56 am | #189 | |
UE1/14 - 5.02V
UE1/14 - 157mv Code:
UE1 pin 1 - 1Mhz solid UE1 pin 3 - 1Mhz but it 'blips' to 0 frequently; I can provide a video to help? UE1 pin 5 - 1Mhz with blip UE1 pin 13 - 1Mhz solid UE1 pin 11 - 1 Mhz solid UE1 pin 9 - 1 1hz solid UD5/14 - 5.18V UD5/7 - 157mv Code:
UD5 pin 11 - 4.55V with no waveform UD5 pin 8 - 1Mhz with the blip Colin. Quote:
19th Jul 2023, 9:29 am | #190 | |
The operation of the gates around UD5 is address-dependent so I think the next thing we need to do is to drop your NOP generator into the CPU socket, and first of all look at these pins again for signs of activity Code:
UD5 pin 11 UD5 pin 8 If the behaviour on the AB0-AB15 lines is as expected, repeat the same observation on the B0-BA15 lines on the other side of the UD13 and UD14 address line buffers, where the behaviour of the lines should be the same. |
19th Jul 2023, 9:47 am | #191 |
I did mean UD1 pin 10.
I'll dig out my NOP generator and report back. Colin. |
19th Jul 2023, 9:58 am | #192 |
I'll be using this as my handmade NOP generator was always 'fun' to work with.
It has LEDs on it - RDY and NMI stay on, RESET starts off unlit but after a couple of seconds, it stays lit. I'll report back the frequencies. https://www.laser.com/product_info.p...oducts_id/1981 Colin. |
19th Jul 2023, 9:59 am | #193 |
UD5 pins 8 and 11 have no activity at 4.55V
Colin. |
19th Jul 2023, 10:18 am | #194 |
All frequencies present and correct on the 6502.
All frequencies present and correct on UD13 UD14 - all present and correct with the exception of pin 17 which should read the same as pin 25 of the CPU and doesn't; no square wave and a reading of 244Mhz. I have checked and cannot get continuity between pin 25/CPU and pin 17/UD14. Colin. |
19th Jul 2023, 10:23 am | #195 |
I have just recalled that pin 25 was the socket which had the broken 6502 pin in it from post #51. I'm guessing the socket is damaged because I can get continuity under the board.
Replace the 6502 socket? If so does anyone know where I can get white sockets? Colin. |
19th Jul 2023, 10:33 am | #196 |
Good work spotting that open circuit on the A15 address line between the CPU and one of the address buffer inputs. After you've fixed that please also check the BA0-BA15 signals on the OTHER (output) side of the UD13 and UD14 buffers as well. We'll look again at UD5 afterwards, since the missing A15 signal may be part of the cause of that.
I can't help you with a source for white sockets but the original Commodore ones have a bad reputation in any case. Yes, replace the socket with a conventional one which will be easier to remove if you ever find a white one to replace it with. Potential 3D printing project: Replicate the plastic frame of a modern conventional socket in white, and remove the contacts from a black socket and fit them into your 3D printed white frame. You should regard this as a tongue in cheek suggestion because I wouldn't think the sort of plastic which works in 3D printers will be heat resistant enough to survive the heat of being soldered in, but maybe you know differently... |
19th Jul 2023, 12:31 pm | #197 |
OK - new socket in, continuity OK and all frequencies OK including pin25->UD14 pin 17.
When you say check the BA0-BA15 signals, am I looking for continuity according to the schematics or waveforms? For example, am I expecting to see waveforms on J9 as per the picture attched? Colin. |
19th Jul 2023, 12:47 pm | #198 |
J9 will be a nice place to pick up the BA0-BA15 signals provided you know which pins of J9 carry which specific signals. The J9 pin numbers are marked on the diagram but it may be less obvious which pins are which when looking at the physical J9 connector. You can instead scope them on the output pins on UD13 and UD14.
UD13: Pins 3, 5, 7, 9, 12, 14, 16, 18, in that order UD14: Pins 12, 14, 16, 18, 9, 7, 5, 3 in that order The frequencies on those pins, with the NOP gen fitted, should be identical to the frequencies on the corresponding CPU AB0-AB15 pins. The waveforms should look clean and square. |
19th Jul 2023, 1:19 pm | #199 |
The only output pin on UD13 that looks right is pin 9. Otherwise there's no waveforms on the other output pins.
UD14 has no waveforms on pin 16 and although the other output pins give me waveforms, they're not nicely square (see attached). Two new ICs (I have spares here)? Colin. |
19th Jul 2023, 1:31 pm | #200 |
That image actually just looks as though the frequency compensation trimmer on your probe is not correctly adjusted, so just try adjusting that while scoping any of UD16's output pins apart from pin 16 to see if you can get nice 90-degree corners on the square waveforms instead of those overshoot spikes.
As to the rest, if you are sure of your findings then it does sound as though UD13 and UD14 have both failed in different ways. They both have their enable pins strapped in a permanently enabled state so they should just function as always-active buffers. There is a possibility that some device which sits on the buffered address is so heavily damaged that the buffers can not drive those lines, but failure of the buffers is much more likely so, since you already have some, it would be reasonable to try changing those first. As per your current strategy, try to get the original ICs out in one piece if you can. |
