Old 19th Sep 2021, 3:46 pm   #1
Ian - G4JQT
Ian - G4JQT's Avatar
Default Increase treble boost?
Is it possible to increase the treble boost of this circuit? I've played with the values of R4, C5, C7 but not made much difference. Or should I be looking at R3, R5, C8, C9? But VR2 adjusts the bass response.
Input pin 6, output C10.
Thanks.
Ian
Ian - G4JQT is offline
Old 19th Sep 2021, 4:04 pm   #2
Radio Wrangler
Radio Wrangler's Avatar
Default Re: Increase treble boost?
Which circuit?
I sometimes miss with attached photos.
Radio Wrangler is offline
Old 19th Sep 2021, 4:06 pm   #3
I think Ian has edited the post to include the circuit now.
Old 19th Sep 2021, 4:07 pm   #4
I do wonder what C11 is doing, can we have a bit more of the circuit?
Old 19th Sep 2021, 4:35 pm   #5
Ian - G4JQT
It's just RF decoupling. It's part of my 'pantry' tx I made years ago. It would be nice to get a bit more treble boost to overcome the Q of the output cct and IF bandwidths.
Old 19th Sep 2021, 4:48 pm   #6
Radio Wrangler
It doesn't look like it ought to work.
The opamp has o/p connected straight to - input so its output is voltage following the divided and decoupled supply line. So the left and right inputs go through passive tone control networks and get shorted to a fixed DC virtual ground.
Either I've missed something, there is an error in the diagram, or that's a rather disappointing circuit.
Old 19th Sep 2021, 5:01 pm   #7
Ian - G4JQT
Yes, you're right David. An error in my redrawing from the original! It works OK, but just want a bit more treble...
Old 19th Sep 2021, 5:27 pm   #8
G.Castle
Try reducing R4 on your diagram to the wiper of the treble pot, also you seem to have too big a capacitor bounding the op amp, 1n not 82p, beware too much boost will make it unstable.
Greg.
G.Castle is offline
Old 19th Sep 2021, 5:59 pm   #9
Diabolical Artificer
Diabolical Artificer's Avatar
Some useful formula's here for such a problem - http://www.aikenamps.com/index.php/tone-control-scaling hope that helps.
Andy.
Old 19th Sep 2021, 7:33 pm   #10
kalee20
I'd say, take the signal to the - input of the op-amp from the other end of the 4.7kΩ resistor, ie direct to the treble wiper!
Then you can have the boost or cut extending to 0 or infinity.
(Though, as others have pointed out, watch for instability in the op-amp at maximum either!)
kalee20 is offline
