3rd Mar 2021, 10:16 pm | #1 |
Reel to Reel Tape Clips
With my latest pair of recorders purchased came a bunch of tapes, all of them were fitted with little white plastic tape clips.
I am sure other people would have seen these but it is the first time I have seen tape clips. One of my pet hates is reels of tape unravelling and getting in a mess, these simple clips seem to do a reasonable job of securing the tape. Also in a bag of cables was an an empty Scotch tape clip bag, so I assume the fitted clips are Scotch. Will have to try and purchase some tape clips. David |
3rd Mar 2021, 11:33 pm | #2 |
Re: Reel to Reel Tape Clips
One annoying thing is when manufacturers cram so much tape onto a reel, so much so that it almost overlaps the spool flange and perpetually comes unravelled. The golden label Grundig 5.75" spools (made by BASF) have a wide hub and tend to suffer from this 'overspill', I find. This is where those clips can come in. I have some of those white ones and also some red BASF ones.
However, they do tend to crush the tape, especially if there's a slightly uneven wind with some layers riding a bit higher above the tape pack, so you can damage those parts if you use the clips. I always try to ensure there's a centimetre or so of space by transferring such 'overspilling' tapes to the next size reel up. I have also had tapes arrive with home made clips made from offcuts of transparent plastic, like part of a blister pack from superglue or something. Worked well!
Regards, Ben. |
4th Mar 2021, 10:33 am | #3 |
I see quite a few Scotch ones online for sale but generally very expensive.
Strange that I have never seen one before, have recieved/purchased large number of tapes especially in the last couple of years. I will watch out for the tape crushing. David |
4th Mar 2021, 10:48 am | #4 |
I made my own from a strip of card from a cereal box. About 1/2" wide x 1 1/2" long and folded into a 'U' shape. I've seen similar things on reels of 8mm cine film, but not specifically for tape, Cheers, Pete.
"Hello?, Yes, I'm on the train, I might lose the signal soon as we're just going into a tunn..." Last edited by Tractorfan; 4th Mar 2021 at 10:52 am. Reason: Added info. |
8th Mar 2021, 5:23 pm | #5 |
I had some scotch tape clips back in the late sixties - must still be about somewhere. The downside is that they damage the tape edge if the spooling is not perfect, as mentioned above.
