Old 20th Feb 2021, 4:30 pm   #101
Travellingwave
Default Re: My first telly TV22
Bit dim still
I might try the diodes again and adjust the ion trap as suggested by Helder
Travellingwave is offline
Old 20th Feb 2021, 4:48 pm   #102
Travellingwave
I disconnected the EY51 and put the string of IN4007 diodes back in. Adjusted the ion trap. If I adjust for max brightness it’s still a bit blurred , if I back off slightly from max brightness it’s about as good as it’s been so far.
Brightness control on max , reducing brightness caused width to increase and height to decrease. Not much actual reduction in brightness till towards the bottom of the range and it tends to lose lock then as well
Old 20th Feb 2021, 4:49 pm   #103
Travellingwave
Think I will get a new EY51 , is it worth getting a new PL81 too?
Old 20th Feb 2021, 4:52 pm   #104
Travellingwave
Corona discharge seems to have gone , maybe the humidity has reduced
Old 20th Feb 2021, 5:30 pm   #105
Helder Crespo
Helder Crespo's Avatar
How does your focus magnet behave? Do you cross a point of minimum blur near its centre position? Or is it closer to one of the ends?
Helder Crespo is offline
Old 20th Feb 2021, 6:40 pm   #106
Travellingwave
I would say focus is better towards center of focus magnet adjustment
I have adjusted picture centering and line linearity and apart from not being the sharpest picture it’s not bad - I’m not really sure what to expect from a 70 year old telly.
Good news is the LOPt seems to be running nice and cool
Old 20th Feb 2021, 6:42 pm   #107
Travellingwave
Ordered a NOS EY51 and PL81 should I get a line drive valve too , read these lead a hard life
Old 20th Feb 2021, 7:28 pm   #108
Helder Crespo
A more quantitative way of checking focus and resolution is looking at the 2.5 and 3 MHz vertical gratings in the testcard. If you can resolve the first, that's already very good and what most of us have. If you can resolve the second, you have a cracking set with impeccable alignment.
Old 20th Feb 2021, 7:56 pm   #109
Travellingwave
Presume those are the two bands furthest to the right?
Old 20th Feb 2021, 7:57 pm   #110
beery
beery's Avatar
Hi Travellingwave.
I'm a bit confused by this. Basically, if the brightness control is working then you need to set it to a level where you can just see the raster clearly and then adjust the trap magnet by rotating slightly and moving it forwards and backwards slightly until the raster is at its brightest. If the focus is then off because the brightness is too high, the brightness needs to be reduced using the brightness control. If that does not work, then you need to investigate the brightness control further. It is not a good thing to use the trap magnet to reduce the brightness as it will shorten the tube life significantly.
I'm also confused as to why reducing the brightness would cause the set to loose sync unless you actually mean the contrast control or reducing the brightness is causing excessive corona discharge.
Andy
Last edited by beery; 20th Feb 2021 at 7:58 pm. Reason: Left out the word backwards
beery is offline
Old 20th Feb 2021, 8:04 pm   #111
Helder Crespo
Yes.
Old 20th Feb 2021, 8:08 pm   #112
Freya
Freya's Avatar
Seem to ask this alot, but are you using an attenuator with the hedghog, needs to be
something around 18dB. It may be overloading the set.
Stephen
Freya is offline
Old 20th Feb 2021, 8:10 pm   #113
Helder Crespo
Or perhaps it's just too much contrast/gain. My Hedgehog II works fine without any attenuation. Same for the Aurora.
Old 20th Feb 2021, 8:12 pm   #114
Helder Crespo
On the other hand, if the contrast is somehow stuck to a high value (pot or resistor?) then attenuating the Hedgehog output can be a good idea at this stage.
Old 20th Feb 2021, 8:17 pm   #115
Travellingwave
No I don’t have an attenuators.
I’m just going to fire her up and see what gratings I can resolve
Thanks for all the help , would be lost without
Old 20th Feb 2021, 8:20 pm   #116
Helder Crespo
Fixing the pot/resistor issue in the contrast control should help a lot. You mention that the control only works when at maximum position, which is way too much assuming that everything else is ok. I believe it will be difficult to see fine gratings in these conditions.
Old 20th Feb 2021, 8:33 pm   #117
Travellingwave
Thanks Helder , I think you are right , if I turn the contrast down the picture shrinks and goes further out of focus , if I turn further something is going into oscillation , still have a frame but just noise.
In terms of gratings - I assume we are talking about vertical bars
If I adjust ion trap for max brightness I would say I can see the first three though they are not clearly defined. If I adjust ion trap to a dimmer picture they are much sharper and can get all except the last one.
Old 20th Feb 2021, 8:42 pm   #118
Helder Crespo
Yes, the vertical bars. That's fine for a quick check, but it's not a good idea to adjust the ion trap magnet to a dimmer picture. You will be overdriving the tube with excessive beam current (and overloading the output stage), even though most of it won't reach the screen.
As for the oscillation, it seems that you loose line synch (horiz. hold), which can happen if contrast is too low/high.
Old 20th Feb 2021, 9:11 pm   #119
Travellingwave
Why would contrast affect picture size? It’s way back from the time base circuits? Anyway will have a look tommorrow
Old 20th Feb 2021, 9:13 pm   #120
Travellingwave
Anyway - glad there is something to fix , it would be boring otherwise
