27th Mar 2004, 7:45 pm | #1 |
Lubricating variable resistors
What magic potions do you find effective on switches and pots? How do you get them inside some of the better sealed parts?
I've just bought a can of PTFE dry lubricant. It's absolutely magic on locks etc as it does not gum up or attract dust. I wonder if it would be any good on pots etc. |
27th Mar 2004, 7:55 pm | #2 |
Re: Lubricating variable resistors
I normally go for Electrolube EML or Servisol Super10...but yes, getting inside some of the pots is tricky sometimes when there's no obvious hole to squirt in!
Steve J |
27th Mar 2004, 8:25 pm | #3 |
I also use Servisol although recently I've used Maplins own switch cleaner - seems to be just as effective although I haven't been using it for long enough to see if there are any longer term implications.
As for pots which are bad and are sealed - I tend to take them apart or if that is not practical I try to replace them with a pot that does have holes for applying cleaner. |
27th Mar 2004, 9:10 pm | #4 |
Hi all.
The best thing to use on pots and switches is a proprietry switch cleaner. I remember once, someone used an unknown brand of cleaner and it disolved the track in a pot! He thought it was all the dirt running out!. Another time he used it on a system switch in a dual standard TV and it went up like petrol. You should find that anything supplied by RS, Maplin, CPC or Farnel will be perfectly OK. You're right about some pots. The really good ones do not have any holes to squirt the stuff in and I've had to take a few to bits. So far I've not had to scrap a pot and always managed to re-assemble it OK. Rich.
28th Mar 2004, 8:17 pm | #5 |
In my fairly limited experience I have found that just squirting in switch cleaner works for a short while, but the crackling soon returns. I have started to take the pots apart as a matter of course. As much of a problem as dirt seems to be that the spring that carries the wiper becomes loose and allows the wiper to lose contact with the track. This problem particularly affects those with a combined on/off switch, presumably because of the greater use they get.
Taking it apart allows for the careful re-tensioning of the spring. Probably many repairable original pots are replaced when the switch cleaner does not work. Paul
Paul |
30th Mar 2004, 3:15 pm | #6 | |
Gordon. Last edited by Paul Stenning; 29th Dec 2004 at 12:48 pm. |
30th Mar 2004, 4:30 pm | #7 |
Might be good for variable capacitors and tuning drive shafts,pulleys etc. though.
