13th Jun 2021, 6:45 pm | #21 |
Re: Modifying an inductor?
Remember, your inductor is not a pure inductance, there is distributed stray capacitance amongst its turns. This distorts your inductance readings and apparent resonant frequencies, especially as you approach the self-resonance frequency. Modelling errors can get out of hand and rather counter-intuitive things appear to happen. 2-layer coils really make the capacitive effects worse. expecially if you laid the turns out there-and-back-again-over-the-top.
13th Jun 2021, 8:07 pm | #22 |
Yes, I sort of know about those unwanted capacitances. I just don't have any experience to know what to expect or how to design them into the filter. So I just work it out using what I do know, look up how some other people have done it, verify my idea with a design tool, check with someone on here who knows a lot more than I, then breadboard it and see what happens. So far I've been into several dead-ends, or learning experiences as I prefer, and have learned something about how LC filters function. What I haven't done yet is to achieve the design objective.....
13th Jun 2021, 10:03 pm | #23 |
Of course, I need a negative capacitor. Now, where’s my RS catalogue.....
13th Jun 2021, 11:52 pm | #24 |
Your inductor IS a negative capacitor!
Snag is its value changes with frequency. And you get free, stray, positive capacitors with it David
17th Jun 2021, 5:20 pm | #25 |
A successful bit of breadboarding confirms that the values now are near enough correct. Using the circuit below and a TTL-level square-wave input, I get a peak sine wave output a few cycles under 1MHz - I have ten 15µH chokes to try, so I'm sure one of them will be closer to my preferred frequency. I have a choice of poly 3n3 or ceramic 3n3 - both work, but will it matter which I use?
17th Jun 2021, 11:58 pm | #26 |
It probably doesn't matter much but if the 3n3 ceramic caps are class 2 types they won't be that stable over temperature and the Q won't be that great either. I'd fit the poly ones assuming they aren't ancient and/or enormous.
A good choice would be a modern Wima 3.3nF cap as these are small, accurate and stable.
Regards, Jeremy G0HZU |
18th Jun 2021, 12:31 am | #27 |
Note also that if the ceramic caps are class 2 they will also have a degree of non-linearity with voltage. A drive level of 4Vpkpk might be enough to generate some unwelcome distortion in the capacitors but I think it depends on the dielectric type and also the voltage rating of the cap.
