Old 10th Jun 2021, 8:40 pm   #1
John_BS
John_BS's Avatar
Default Fault in ECL86
I've been revisiting a Dynatron record player which I'd previously "restored" circuit-wise. The original Mullard ECL86's tested 100%, but having changed the cartridge for a more appropriate type, I was greeted with truly epic distortion.
Big sigh and everything out of the case again: the phase-splitter triode should have 30 odd volts on its cathode, but it was up at 100V and only a few volts below the anode. Not having found any component problems, I removed the valve and tried it on the AVO. It said there was an issue with insulation "anode to rest". When I removed it and gave it a firm tap with a screwdriver, all came good. Back in the record player and the biasing is now correct. Is it safe to leave this as it would be a shame to replace one of two original valves with 100% emission.
John
John_BS is offline
Old 10th Jun 2021, 9:06 pm   #2
Ed_Dinning
Default Re: Fault in ECL86
Hi John, it may or may not have a lot of life in it yet.
Analyse the circuit and see if the fault re-appears it will cause expensive damage. If not a note to self within the machine as to what the problem was
Others may disagree
Ed
Ed_Dinning is offline
Old 10th Jun 2021, 10:09 pm   #3
John_BS
John_BS's Avatar
Ed: no, it's got 100K to both anode & cathode, so only passes 1mA !
John
John_BS is offline
Old 11th Jun 2021, 12:25 am   #4
kalee20
It's probably some debris, unfortunately rattling around in the valve.
If it works, leave well alone - it may carry on fine, but die if you pick up the equipment and turn it on its side.
As nothing is going to get damaged, according to your checks, you might as well carry on and enjoy its service.
kalee20 is offline
Old 11th Jun 2021, 10:27 am   #5
John_BS
John_BS's Avatar
It's back in and working, so fingers crossed!
Thanks for the advice.
John
John_BS is offline
